3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a Cardboard Mini-Castle!
  • last photo ←
In this Instructable, I will teach you how to easily make a miniature castle made (With fully functional Drawbridge!) completely out of Cardboard and tape!
The Materials you will need:
- Cardboard
- Tape (Any kind)
- scissors
- Something to poke holes with.
- Pencil or Pen
- Ruler
- Paint (Optional)
- String
Step 1Making the Bigger walls of the Castle Base.
For the bigger walls of the Castle base (The middle part) you will need to measure and mark down 20cm x 12cm on a piece of cardboard and cut it out with the scissors. After cutting out the piece of Cardboard use it as a template to cut out another piece of cardboard the same size.... Now, to form the drawbridge, poke two holes 5cm apart near the middle of one wall. From the hole, cut 8cm upwards and cut the 5cm left and back down 8cm (DO NOT CUT RECTANGLE SHAPE OUT). You should now have a flap sticking. To make this Drawbridge work you will need to tape your string to the back of the drawbridge and poke small holes in the castle base, to fit the strings through. Now, tie a knot in the string and you should now be able raise and lower your drawbridge by pulling the string.
2 comments
Aug 15, 2009. 8:13 AMguitarmonk15 says:
cool! make some pen guns and little guys out of paper and have a battle!
Jul 27, 2009. 6:54 PMSnugglesTheRock says:
Wow!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:SnarflesTheWolf
