3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a Cardboard Mini Fridge!
How to make a Cardboard Mini Fridge using household and inexpensive materials!
Step 1Materials
Materials
Cardboard Box
Scissors
On/Off Switch
Heatsink
Peltier Unit (Available from Ebay)
AC Adapter (7.5 Volts works nice)
Optional:
Paint
Shiny Tape
Standoffs
etc.
20 comments
Oct 3, 2011. 9:45 AMGrundalizer says:
Cool project. Were you able to take a final temperature reading after it stabilized for a while? How cold does it get?
Apr 12, 2011. 5:18 PMscreasy says:
I have the same shirt as u :D
Jun 13, 2011. 9:38 AMSMarshall14 says:
please tell me where you got it
Jun 13, 2011. 2:10 PMscreasy says:
I think it was at walmart ?
Jun 13, 2011. 2:41 PMSMarshall14 says:
we dont have that in the UK but we have asda which is owned by walmart so that might work
May 16, 2011. 12:59 PMantisback says:
If I increased the power and insulated it more could I use this as a freezer
Feb 6, 2011. 7:34 PMNamier says:
Hey man, was wondering is i put two heat sinks like one on eache side would it help to ge tthe cold air spreading?
Jan 18, 2011. 8:16 PMMooTaters says:
It would make more sense to cool it from the top. Cold air drops.
Feb 12, 2010. 3:00 AMdarkevilapie says:
wouldnt it be better if u put the peltier on top of the fridge (i llove ur fridge) cuz cold air drops and hot air rizes, and put a heatsink on the coolside of the peltier en aheatsink with fan on the hot side? and is is possible to connect this on usb power suply (drinks when gaming :) )
Jul 15, 2010. 4:44 AMTomcat94 says:
Now tell me, has anyone here actually tried that and achieved better results than having it on the bottom? Or is this all theoretical?
Aug 3, 2010. 2:15 AMdarkevilapie says:
better results? of course there has been many research about heat and cold, take he central heating system: cold air comes from the bottom an gets heated up then it rises traveling to the top. but, if u put the cold side at the bottom then the drink is touching the heat-sink, if the drink is in a can then the metal conducts the heat better than just cooling the air in the fridge. conclusion: cold goes down and heat rises, contact with the object conducts the heat easier PS made my own fridge :P it holds 2 1.5 ltr cola bottles
Aug 28, 2009. 7:19 PMlint66 says:
where do u purchase a heatsink
Jun 12, 2010. 2:35 PMkorgoth25 says:
checck your area for a ESS (electronic supply store) they have almost defintly have all these parts
Sep 14, 2009. 12:23 PMshawntherobot says:
i would be inclined to check some online stores just type in heat sink on google
Jan 17, 2010. 8:10 PMFashim says:
Ohk Im Slightly Confused (Like Always :D) Anyways Could you just use a Heatsink Unit.. My Idea was to Get a Foam Box or a Cooler and Install a heatsink unit and 2 Fans on the sides connected to an Old PC Power Supply? Would that Work?
Jan 17, 2010. 8:11 PMFashim says:
+ If you can use Thermal Paste.. Where would you Apply it?
Aug 21, 2009. 7:56 AMdark sponge says:
Cool, I just have a couple of suggestions: 1. Using thermal paste will greatly improve heat transfer 2. I noticed in the video that a lot of the heat sink from the hot side is inside of the refrigerator. This will prevent the inside of the refridgerator from becoming cool.
Sep 6, 2009. 3:45 PMdark sponge says:
Yay, I built mine! It uses two phone chargers for power, two heatsinks from old CPUs, and has fans to improve efficiency. It also uses and insulated cup instead of cardboard to keep the heat out.
Sep 12, 2009. 2:48 PMfenrisilver says:
Did you use a peltier unit? I'm thinking of making something like this. I have plenty of materials for the case and insullatio, and I'll buy a peltier if I must, but my problem is with the heatsink. I found an "Evercool Chipset Thermal Package" in my familys computer desk. It's been in there collecting dust for years, It's probably long been obsolete. I'm sure it works, It's just I have no Idea how to use it or power it, and the page came with no instructions (It was pretty cheap).
Sep 13, 2009. 11:43 AMdark sponge says:
Yeah, mine uses a peltier. Is that chipset thermal package a heatsink, a peltier, or both? If I know exactly what it is, I should be able to help.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:akosin
