Step 10Making wider pleates
Figure out your front apron length, under apron length, pleated length and total cut length as if you were using 2 inch pleats (see step 2 in the instructable).
Front apron and under apron length's are 1/3 your waist measurement.
Pleated length is 6/3 (or twice) your waist measurement
Total cut length is waist measurement / 3 * 8 + 1
To modify it for longer pleats decide your desired pleat length
Take your desired pleat length and multiply it times 3
Divide that by your pleated length. Use only the whole number, drop the remainder. This will be your total number of pleats.
Take your total number of pleats and multiply it times your desired pleat width times 3 and subtract from your calculated pleated length
Divide that number (which is in inches) by 3
Take that final number, add it to your front apron length, under apron length and subtract it from your total cut length.
Obviously you'll need to do these calculations before you cut your fabric.
Example: I have a 45 inch waist and I want 4 inch pleats
Normally (for 2 inch pleats) I'd have a 15 inch front and under apron, my pleated length would be 90 inches and my total cut length would be 121 inches as figured in step 2.
My calculations would be
4 in pleats * 3 = 12
12 / 90 = 7 (dropping the remainder)
7 * 4 * 3 - 90 = 6
6 / 3 = 2
New front and under aprons length is 17 inches
Total cut length is now 119 inches
I've tried this out on paper a couple times with different waist measurements and it seems to be correct. I have to recommend rounding your waist measurement up to a number divisible by 3 though, it makes the calculations much easier and when you test fit the kilt in step 5 you'll take in the difference and not even notice.
To check your math use these 2 formulas
Pleat width times # of pleats plus front apron length = your waist measurement
Pleat width times # of pleats times 3 plus front apron length plus under apron length plus 1 = total cut length
I know this is a little complicated but I hope it helps.
Feel free to message me if you have any more questions and post a pic of your completed kilt in the comments section.
Good Luck
Add Comment
