3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a Chandelier using Mason Jars
  • last photo ←
We made this chandelier to be the centerpiece of our dining room.  You can check out this DIY and Design projects like this one on our blog, www.KaraPaslayDesigns.blogspot.com.
And before I get started, I want to make a DISCLAIMER: I am not an electrician and will not assume responsibility for any damage that occurs as a result of you attempting this project.  If at any point you feel uncomfortable, hire an electrician!  We have had this chandler installed in our house for about two years without any problems.
There are a lot a steps involved but I will do my best to explain things in terms anyone can understand. So, here goes. . .
Step 1
  • last photo ←
First gather all your materials. You will need:
- Canning Jars with lids (6 large, 9 widemouth, 6 small)
-Wire (18-2 Lamp Cord)
-#10 Washers
- Hex Nuts (that will fit your nipple (which is the threaded metal rod))
- Steel Nipples
- Small Hose Clamp
- 4 Keyless Sockets
- 4" offset crossbar
- 4" PVC cap (found in plumbing section. We used this as the ceiling plate because it provides a lot of room to accommodate all the wires that are coming from the fixture.
-3" machine screws (to attach the ceiling plate to the crossbar)
-2 Acorn nuts
-2 wire nuts
16 comments
Feb 27, 2012. 1:12 PMwildviolets says:
this light is beautiful. I have made one from an actual standing lamp, that my daughter's bunny chewed the wires on. I just bought a swag lamp kit and turned it into a mason jar lamp. I love it....thanks for sharing
Feb 10, 2012. 6:22 AMtxbd75 says:
I built one of these as a prototype with a 40 watt bulb and had hung it in the basement overnight to see if the heat of the bulb in a closed container would cause any problems. Here's what I found:
1. The jar glass was dangerous to touch
2. The insulation of the wire coming out of the jar was hot and very soft, which is how it feels before the insulation melts, which would be dangerous.
3. It is beautiful!
You make these things, so maybe you are doing something else to dissapate the heat. Any ideas? I'd like to make a chandelier with these jars, but frankly I don't consider it safe (As an electrical engineer, I worry more than others).
Feb 6, 2012. 1:03 AMVinsu says:
Funky :) 4 stars.
Feb 3, 2012. 3:15 PMbg_askins says:
great look! I'll be making one for my grandmother's house.
Jan 31, 2012. 6:23 PMjessandstavro says:
I love this! Very cool, nice work! Redneck chic? I was thinking more hillbilly whimsy. ;)
Jan 29, 2012. 6:53 PMPatrik says:
You could also try inserting a bunch of the flickering candle LEDs (see e.g. http://evilmadscience.com/component/content/article/189), for a "jars of fireflies" effect. Maybe put one bright bulb in the center, so you can switch between mood lighting and bright illumination.
Jan 29, 2012. 9:50 AMlsmith254 says:
Hi...I hope you don't mind, but I have a suggestion. Since only about a quarter of the jars have working lights why not cut your materials list by using coated cable(similar diameter, look, and less weight) that is folded in half at the top and draped over a short rod or bolt? You can then save time cutting all those short nipples, and use the zinc sleeves which are compressed over the cable ends. You might even get the hardware clerk to do that for you! If you use the "folded cable" method, you might even be able to manually alter the height of individual jars to change the look by pushing one cable up and/or pulling the other side down (watch for movement) coated or uncoated cables, weigh the desired qualities yourself.
Jan 29, 2012. 9:58 AMlsmith254 says:
One last thing...I think I would paint the cardboard socket cover white or silver, and glue the tiny clear glass glitter or beads all over it, to increase the sparkle factor. Great instructable!
Jan 27, 2012. 3:10 PMStrombergundy says:
This is awesome!
Does the light diffuse well through the jars? I find that lights with just a clear glass casing cast too harsh of light for me. I would be tempted to frost the inside of the jars with a glass etching solution so the light is softer.
Jan 29, 2012. 9:25 AMlsmith254 says:
Look up simple sand blasting tool on here. It's very easy to make, and there is also a simple sandblasting box made from a bin...I made the tool, and just need to decide which bin I am going to cut up and use for my sandblasting box. Great way to use canning jars that have small chips on rims, or can no longer be used for food!
Jan 26, 2012. 6:27 PMimbigman says:
I love this, Something differant.
One thing though. You wrote in your disclaimer:
"I am not an electrician and will assume responsibility for any damage that occurs as a result of you attempting this project. "
You may not want to assume responsibility. Could get you in big trouble.
Great project. I think i'm going to give it a try.
Jan 26, 2012. 9:19 PMl8nite says:
redneck chic ! love it
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:timpaslay(Kara Paslay Designs)
