How to Make a Crossbow - PVC Crossbow
Introduction: How to Make a Crossbow - PVC Crossbow
How to make a Crossbow - PVC Crossbow
(Watch Video)
Here is a crossbow made with PVC. It is easy to make with common tools and a little time. You do not need any heat or reshaping of the PVC to make this. It is powerful enough to put a hole in a wall from across the room, so do not play with this inside your house.
Do not point his crossbow at anyone or any living creatures because it can hurt them badly.
Just remember that PVC is only a form of hard plastic. It can and will break if too much weight or force is applied and injuries can occur. Please use caution when using anything made from PVC.
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    With a PVC cutter that can be found at most home improvement stores. Can cost $10-$20(US).
    Do yo have to buy different bits to do different size cuts?
    And will it do the curved cuts for the string?
    The cutter works on all pipes up to a certain size (each cutter is different).
    For the ends, I used a saw. The cutter is only good to cut all of the way through the pipe.
    Thanks very much!
    Do you recommend a brand?
    Most brands should work as long as they look heavy duty
    Neat. This would be a nice base/blueprint for building a homemade nerf gun for NIC wars. This is very cool!
    Well you are certainly doing a great job:):):)
