How to Make a DIY Antenna(Free T.V.)
8,502
19
4
Posted in TechnologyElectronics
Introduction: How to Make a DIY Antenna(Free T.V.)
You probably wanted to get free T.V. at some point, and this instructable will help you with that!
Step 1: What You Need
Electrical Tape Scissors 2 Jumper Wires Aluminum Foil 2 Paper Plates A Coaxial Cable A T.V.
Step 2: Getting Into the Coax Cable
Take your scissors and cut off one end of the coaxial cable. You should get something like that. Take the wires on the cable and twist them all together.
Step 3: Adding Aluminum Foil to the Plate.
This step is very straight forward, just attach aluminum foil to the plate and secure it on.
Step 4: Attaching Jumper Wires to the Plates
This one is easily done. Just attach the jumper wires to the aluminum foil on the plates.
Step 5: Connection to the T.V.
Now for the good stuff, connecting to the TV and getting the TV stations. You want to tape both dishes to the window, aluminum foil facing out of the window. Then connect the coaxial cable to the TV and switch the setting to antenna in the TV settings and scan for channels. You have TV.
    • Pocket-Sized Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    4 Comments
    I have a question. Do you connect the wires around the foil to the foil. And then connect that connection to the middle copper wire?
    Cool, so tip for newbies, do not let the foil, wire or anything metal that is connected to this touch the ground, all of the electricity (channels travel on electricity) will dissapate (go away). But yeah it picked up 69 channels! But my TV decided to save only 28.
    I picked up 69 channels (without using the window method) and it saved 28!
