How to make a Daft Punk Guy Manuel Helmet and costume!
 by FennecCooper
Contest WinnerFeatured
Step 13: Cut out the visor and place it on your vacuum form
So, the title of this step pretty much says it all.
Take your dremel and slowly start cutting the visor off of your cast (This will be used later for the vacuum forming process)
Once you have your two separate pieces, you might want to already paint the cast body and leave the visor untouched, I put primer on mine because I wanted too, you could do so as well : )
So since painting it chrome would take too much money and time, I decided to do the Alive 2007 Encore version of guy manuels helmet.
If you want to do this version, then you are going to need some EL wire (Red)
I painted my body cast with car paint (Black) and sanded it with 2000 grit sand paper.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
