Introduction: How to Make a Desk Organizer
This Desk Organizer is capable of holding rulers, 2 calculators, protractors, papers, and tape. This is mostly made out of PVC piping and fabric.
Step 1: Gathering the Materials
Materials you will need:
PVC pipes:
Lengths:
two: 8 1/2” X ½”
four: 3 3/4” X ½”
four: 1 3/4” X ½”
three: 3 3/4” X ½”
one: 5” X ½”
five: 1 1/2” X ½”
one: 1 1/2” X ½”
Fittings:
T-Connector-4
Corner-Connector-8
90 Degree-Connector- 2
Wood
Length: 4"x 10 3/4" X 1/4"
8 nails
Fabric
3D Printed attachment
Tools you will need:
PVC Cutter
Tape Measurer
Pencil
Needle and thread
3D Printer
Screwdirver
Hot Glue Gun
Step 2: Building the Base
1)Construct a 8 1/2” X ½” pipe. (Either find a pipe the proper length or use a PVC Cutter to cut to the proper length)
2)Construct two 3 3/4” X ½” pipe. (Either find a pipe the proper length or use a PVC Cutter to cut to the proper length)
3)Use a T-Connector to create a 8 1/2 pipe
4)Construct two 1 3/4” X ½” pipe. (Either find a pipe the proper length or use a PVC Cutter to cut to the proper length)
5)Use four corner connectors and construct a 8 1/2” by 4" rectangle
Step 3: Building Up
Construct 3 7 1/2” X ½” pipe. (Either find a pipe the proper length or use a PVC Cutter to cut to the proper length)
Put pipes in slots A,B and C
Step 4:
1)Construct a 5” X ½” pipe. (Either find a pipe the proper length or use a PVC Cutter to cut to the proper length)
2)Put pipe in slot D
3)Construct a 1 1/2” X ½” pipe. (Either find a pipe the proper length or use a PVC Cutter to cut to the proper length)
4)Use T-connector and the 1 1/2” X ½” pipe and connect them to the left side of the T
5)Put T-connector on pipe in slot D
6)Construct a 1 1/2” X ½” pipe. (Either find a pipe the proper length or use a PVC Cutter to cut to the proper length)
7)Put pipe in the remaining slot in the T-Connector in slot D
8)Use a 90 degree angle connector to make a hook
Step 5:
1)Construct a 1 1/2” X ½” pipe. (Either find a pipe the proper length or use a PVC Cutter to cut to the proper length)
2)Use T-connector and the 1 1/2” X ½” pipe and connect them to the left side of the T
3)Put in slot E
4)Construct a 1 1/2” X ½” pipe. (Either find a pipe the proper length or use a PVC Cutter to cut to the proper length)
5)Put in the middle connector
6)Use a 90 degree angle and put on the 1 ½ pipe
7)Construct a 1 1/2” X ½” pipe. (Either find a pipe the proper length or use a PVC Cutter to cut to the proper length)
8)Construct a 4 1/2” X ½” pipe. (Either find a pipe the proper length or use a PVC Cutter to cut to the proper length)
9)Put in slot E
Step 6:
Use a T-Connector to create a longer pipe
Use four corner connectors and construct a 8 1/2” by 4” rectangle
Step 7:
Step 8: The Making of Calculator and Ruler Pouches
1) Using a need and thread construct 2 pouches for the calculator and another for the rulers
2) Using a hot glue gun, attach pouches onto the PVC Pipe.
Step 9: Attaching Tape Cutter
1) Using a hot glue gun, attach 3D printed piece on slot E.
Step 10: Attaching the Wooden Base
1) Drill 4 pilot holes in the four corners
2) Attach 4"x 10 3/4" X 1/4" to base
