Step 2: Preparing the design
I used GIMP to remove all the horns and the face and lower jaw, then printed off 2 resized images onto the card stock.
These were then cut out, and I worked out where I wanted to cut and where I wanted to fold.
The two side were then glued together at the nose and the general shape and dimensions were worked out.
I used more card to fill the gaps, sticking them in with masking tape.
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
Your panting job is phenomenal, by the way.
1. what were the size ratios that you used when you resized the image in the GIMP editing program? further, how did you calculate the measurements for the skull pattern?
2. in place of card stock like you mentioned, would white posterboard work? if poasterboard wouldn't work, what'd be a better material to use?
2. Nope posterboard would be too thick to get the bending and shaping right. I used thin card so that I could get it into shape easily. Once the resin goes on it becomes very strong and stable ready for the other operations.
I wanted to make one of these for my schools crazy hat day. There are a few problems I have though;
Is there an easier way to create a similar effect with easy to find/use supplies?
Can you post the pictures of the skull and horns as a file that we can download and print onto the cardstock?
And for creating the "bone" texture with Bondo is there a easier way without a dremel? I'm only in 8th grade and I don't think I'm allowed to use any sort of power tool.
Thanks!
http://fc01.deviantart.net/fs26/f/2008/175/5/8/Dragon_Headdress_by_McGibs.jpg
I'm not sure if the card would be strong enough without the resin, but you could try using a few coats of white school glue (PVA) instead. Should work but will take a long time to dry between coats.
You don't need to use a Dremel, it can all be done using sandpaper, BUT it will take a very long time, and require quite a bit of effort to get a nice finish.
Talk to your craft, or shop teacher and see if you can work it out with them.
Best of luck!
