Or a half-a-gigamonica
or an 8th-gigamonica
or a 'Blues-tooth adaptor'
etc. etc.
The other day I was screwing around in the shed and made something wonderful. I managed to get a 512mb flash card inside a harmonica and have it still playing. Today, having bought a new harmonica and a new flash drive, I plan to repeat the process with pictures.
YOU WILL NEED
o a cheap $10 dollar-ish harmonica (I've only used the same brand and model - twice, not sure how other types work)
o a smallish flash drive (the 2gb one here didn't end up fitting)
o OR a smallish bluetooth adaptor / anything small and usb connected
o a hack saw
o rusty garden clipper thingies (I used these the first time to trim the flash drive... no seriously)
o needle nose pliers
o duct tape / electrical tape
o rusty craft knife (I only used this because I couldn't find a screwdriver to fit)
o Those yellow grenades are optional (long story short: "Flash grenades")
Remove these ads by
Signing UpStep 1Pull stuff apart
Note that you need to hold the other end of the screw steady as you spin this end, or you will waste several minutes screwing to no avail.
Once you've done that, you should be able to see what the harmonica looks like inside.
QUICK HARMONICA LESSON:
I don't know much about them either, but when you blow through the holes, those little prongy bits you can see here apparently vibrate and make the noise, similarly, when you draw (suck) the ones on the inside do.
Now, lets take off these parts. The first time I did this, I used the actual case of the harmonica to undo the screws here, this time they were too tight and I had to find a real screwdriver.
(NOTE keep track of where those plates go. when you put them back on you need 1 set of prongs sitting out, on set sitting inside and all the big bits lined up with the big bits etc.)
If you try and play it here, the draw notes won't work, they need the case on.
17
comments
Add Comment
lemonie
says:
Add Comment
