Please note that I do NOT sell these (for multiple reasons-see the comments below.) All requests to make rings will go unanswered so please don't ask! You can get nice Green Lantern rings from my friend Batjeepster here- http://www.facebook.com/batjeepster.rings
Now go make your ring and repeat after me:
"In brightest day, in blackest night, no evil shall escape my sight! Let those who worship evil's might, beware my power.. Green Lantern's light!"
Remove these ads by
Signing UpStep 1Materials
All rings will require a wax pattern so for that you will need:
Jeweler's modeling wax (both ring carving shape and round sprue wax) - available from jeweler's supply stores or http://www.ottofrei.com
Dremel tool or flex shaft tool
Files/carving tools
Fine sandpaper/steel wool
For the resin ring:
X-Acto knife or scalpel with curved blade
Silicone RTV molding compound
Urethane casting resin- I use Alumilite casting resins and RTV silicone but Smooth-On is also a good company
http://www.alumilite.com
http://www.smooth-on.com
For the glowing ring:
Clear casting resin- I've used both epoxy resin and polyester resin made by Cast'n Craft- it's sold at craft stores like Michael's and Hobby Lobby
Transparent green dye- Cast'n Craft produces this for its clear resins
3v watch battery- I used a CR1025 lithium cell
Green LED- I used a 5000mcd super bright 3mm LED (part #NTE30031)
Clear 5 minute epoxy
For the cast silver ring:
Centrifugal caster
Burn out furnace
Steel flask
Vacuum table
Ceramic casting investment
Polishing motor/buffs
These are just the basics- I'll get more into materials in greater detail in the individual sections.
A note about safety- Many of these procedures require the use of proper safety equipment as well as adequate ventilation. Please follow the manufacturer's recommendations reagrding safety and health warnings on all resins, paints and casting supplies.
You would probably be better buying a sheet of cast acrylic cut to the size you require. This should be a bit bigger than the screen to allow for fixings.
There are many places where you can buy cast acrylic
I have bought materials from http://www.westwardplastics.co.uk/index.php and found them to be reasonable, I was in Bristol and collected in person to avoid delivery charges and they let me take some useful sized bits of plastic from their scrap bin.
