Step 7Casting the silver ring
It's pretty uncommon for people to have this type of specialized casting equipment so I'm keeping this part pretty short- it's really just here to give people some idea of the processes involved. My recommendation is to carve your wax model and take it to a local jeweler or trade school and see if they will cast it for you.
To cast the ring in sterling silver first the wax model of the ring is attached to a sprue base. Unlike resin casting there is only one sprue attached to the bottom of the ring. This then has a steel flask placed around it.
Next a ceramic casting investment is mixed, vacuumed and poured into the flask and then the flask is again placed in a vacuum chamber to remove any air bubbles.
After an hour, the rubber base is removed and the steel flask is placed into a burnout furnace overnight. The wax will melt out of the ceramic, leaving a cavity for the molten metal to flow into.
The next morning the flask is pulled from the oven and is placed into a centrifugal caster. The proper amount of silver is placed into the crucible in the caster and is heated with a torch until molten.
The caster is then spun and the centrifugal force throws the metal into the ceramic mold. The steel flask is then removed from the caster and is set aside to cool.
After a couple of minutes the flask is placed in a large bucket of water and the ceramic dissolves, leaving a cast silver ring.
The rough casting then has the casting sprue cut off and is cleaned up using a Dremel/flexshaft tool and sandpaper.
http://www.ottofrei.com/store/product.php?productid=14265&cat=0&page=1
