Introduction: How to Make a Hammer Handle!
Prerequisites:
Basic Metal Shop SBU: MTL103 at the TechShop
Basic Wood Shop SBU: WOD101 at the TechShop
Materials:
• Hammer Head (this one is a French Cross Pein, hand forged out of tool steel!)
• Wood • approximately 1.5” x 2” x 12” (I used TulipWood mostly because I had it, but I would recommend Hickory for it’s strength and flexibility)
• Tung Oil
• Scrap steel (for wedge)
• Slow cure epoxy
I made it at TechShop! For more about TechShop, check out their site: http://www.techshop.com
Step 1: Cut Material to Size With Band Saw
• Use the band saw to cut your material a 1.5" x 2" x 12" block.
• Next draw the profile of the hammer handle and use the band saw rough out the shape.
Step 2: Shaping
• Use the belt/disc sander to shape the general profile your handle.
• Use a hand rasp or file get into curves and to refine the shape.
• Use sandpaper to smooth the surface of the wood.
Step 3: Tung Oil
• Apply Tung Oil with a soft cloth to finish wood.
Step 4: Steel Wedge
• Find a scrap piece of the sheet steel and cut it down (using the metal band saw) to an appropriate wedge size.
• Use the bench grinder to shape the edge of the wedge.
Step 5: Attaching the Handle and the Hammer!
• Drive the wedge in with a mallet.
• Glue the wedge in place with a slow curing epoxy (slow curing epoxy causes the wood to expand and hold the hammer in place more securely).
