Diana George, Jenna Sobieray, Alex Cossoff and Chris Francklyn
Well today is your lucky day! Now featured on Instructables.com is a jacket that both heats and cools based on one’s body temperature. Incorporated into this jacket is a heating and cooling system that is all powered by something called the Lilypad Arduino. The Lilypad is a microcontroller board used for wearables and e-textiles and is quite simple to use. All you will need is a little sewing background, some materials, and a whole lot of time. With all three, you will be able to have your own equilibrated jacket!
Materials
1 winter jacket
1 zip-in liner
1 Lilypad Pro Kit (http://www.sparkfun.com/commerce/product_info.php?products_id=8873)
1 E-sewing kit (http://www.sparkfun.com/commerce/product_info.php?products_id=8797)
6 temperature sensors (http://www.sparkfun.com/commerce/product_info.php?products_id=8777)
6 tri-colored LEDS (http://www.sparkfun.com/commerce/product_info.php?products_id=8467)
1 flexible solar panel (optional)
1 rechargeable battery (http://www.sparkfun.com/commerce/product_info.php?products_id=339)
1 battery charger (http://www.sparkfun.com/commerce/product_info.php?products_id=8786)
3 ping-pong balls
About a yard of iron-on fabric
**This Instructables only is part 1 of the jacket. See part two for more materials used.**
Remove these ads by
Signing UpStep 1Preparing
* Order these first so you will be able to start once you get your jacket
2. Purchase a ski type jacket with or without a zip-out liner jacket. The jackets do not have to be new—buying used will help your budget and make fatal mistakes less painful to your pocket.
* If the jacket does not include a liner that zips out, you will need to buy one. Make sure to purchase either a fleece or some type of liner that FITS into your shell, the outside jacket. You will need to check this out before buying.
3. You will want to wash you jackets before so that they will be ready to wear when finished.
4. Once you have completed these steps, you will be ready to start fabricating your jacket.
You can wash it but without the arduino, batteries and solar cell, I think??
some day i may see about making something simular to that wen the money becomes available to do so.
I don't see any downside to that at all. lol
eg. in the winter, heat.. in the summer, or inside: cool :-)
Not sure how I would do it though.. maybe a fan and peltier?
How sensitive are the components to moisture? Would getting wet from rain or sweat be a concern?
-Chris Francklyn
Bacterium: Yes, the LED portion could be skipped, but plan on having at least one LED as an indicator of the temperature within the jacket. Otherwise, the only way to know where the temperature readings are is by plugging into a computer.
RichMitch: The purpose of the two jackets is that the electrical components are protected from the elements and potential damage. However, the electronics could easily place on the inside of a single jacket. '
Thanks for the support everyone! its been great to read the comments being posted!
-Chris Francklyn
How does it heat you? How does it cool you? (I'm especially interested in the latter, as the same technique should be usable to make a cooling blanket for a bed, basically the opposite of an electric blanket.)
Homeostasis.
