Step 20Trouble Shooting
- Make sure your connections are working with help from a voltmeter. Test to see where the voltage of your battery has dropped.
- Retry connecting your relay with alligator clips because they are easier to change than threads and wires. This also allows you to find which connections are wrong or broken.
- Hooking an L.E.D. up to your relay helps you know when it is turning off or on.
- Make sure you have edited the code to your design. If you have the wrong analog ports written in, your relay will not work.
- DO NOT LET BATTERIES TOUCH! This causes shorts, sparks, smoke, and possibly fire. You should separate them for the two systems. We even went to the extent of covering the leads with felt so they cannot touch anything.
- You can also try to contact us if you are having problems at: heatingncoolinginfo@gmail.com
- GOOD LUCK:)
HOPE YOU ENJOYED OUR PROJECT! PLEASE LET US KNOW OR SEND PHOTOS OF COMPLETED JACKETS!
You can wash it but without the arduino, batteries and solar cell, I think??
