Step 4The Tail Rotor Blades
When the glue was dry, I drilled a small hole in the middle of the X.
I used a small rivet for the axle, although you could use many different things...wire, paper clip etc. I reversed the nail inside the rivet and also added a couple of washers, more for aesthetic than anything else. Push the rivet through a washer, then the tailpiece, then another washer, then the rotor. At this stage it is just dry-fitting it together, because I still have to spray paint the rotor blades.
Add Comment
