loading
loading
Picture of How to make a Jewellery Roll
How to make a quick and simple Jewellery Roll with two zipped pockets, large pocket and ring holder.
You will need - outer and lining fabric (I used velvet and satin for my jewellery roll), iron-on interfacing, two co-ordinating zips, co-ordinating thread, a small piece of velcro or a metal snap.
Step 1: Cut out fabrics and interfacing
Picture of Cut out fabrics and interfacing
From outer fabric: 20x30cm for the exterior, 8x15cm for ring roll
Lining fabric: 20x30cm for lining, 20x40cm for pocket panel, 2 pieces 20x20cm for upper zipped pocket, 2 pieces 20x10cm for lower zipped pocket, 2 pieces 6x30cm for ties
Iron on interfacing: 20x30cm for lining, 20x40cm for pocket panel
I only used interfacing for the pocket panel and the lining as they were the bits I felt needed a bit of reinforcement but you can reinforce as much as you want.
Press flat the lining and outer fabrics, and iron on the interfacing. Press ties in half lengthwise, then fold raw edges in and press again.
Step 2: Mark the zippers
Picture of Mark the zippers
Lisa has a great tute here for sewing zips at U-Handblog - fold the pocket panel in half and mark the halfway point. I placed zips 3cm and 13 cm below the middle line.
Draw the markers for the zips. Pin one of the lower pocket pieces to the pocket panel, right sides together lining up the bottom raw edges.
Step 3: Sew the zipper openings
Picture of Sew the zipper openings
Sew around the the zip opening and repeat for the upper pocket using an upper pocket piece. Pin the lower pocket piece you've just sewn to the pocket panel to keep it out of the way.
Step 4: Cut the zipper openings and turn out
Picture of Cut the zipper openings and turn out
Once stitched, snip open between the stitching as in the photo.
Pull the pocket lining pieces through the openings and press.
Step 5: Sew in the zips
Picture of Sew in the zips
Pin the zips in place in the openings. Use a zipper foot to sew around the edges of the zip opening. Make sure you pin the pocket linings out of the way when doing this.
Step 6: Sew in the pocket linings
Picture of Sew in the pocket linings
Sew the lining for the zipped pockets to the back of the zippered compartments taking care not to sew anything else in along the way!
Step 7: Topstitch the pocket panel
Picture of Topstitch the pocket panel
Press the pocket panel in half and topstitch along the fold.
skyisblu5 years ago
This is a great idea! Does it get very bulky when filled with jewelry? I guess the size of the pieces would affect that. I am DEFINITELY going to make one for when I travel!
gganis6 years ago
Thank you for taking the time and effort to make this lovely piece.
ChrysN6 years ago
That's a great way to store jewelry when traveling, and it looks really nice too!
barry_0156 years ago
That would make a nice gift...especially if one adds a peice of new jewery too. It looks great!
canida6 years ago
This is awesome! You make it look so easy - I'll have to try it. ;)
