3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a Joule Thief
A Joule Thief (JT) is a step-up voltage transformer based on the working mode of a PWM (Pulse Width Modulation), it produce a oscillation in a inductor with the help of a transistor (2N3904, 2N2222, ...) then the output of the inductor is your new voltage. The result is that you can light a white, blue or even a ultraviolet LED with a single 1.5V cell (AA, AAA or any type of cell, i have used a watch cell too). This "voltage booster" circuit is not very efficient but it can use batterys that are near depleted. I whud not power up a microcontroler are anything that whud be disturbed by the voltage and power oscillation of the output, there are some dedicated step-up voltage boosters like the IC from Maxim with a 90% efficiency. With a bigger inductor and another transistor it is possible to get some very high voltage, i have see on the web some JT that can light up a neon tube from a 12v bike lead acid battery.
Step 1Tools
Solder iron, Dremel, Hot Glue, Cutter or Exacto Knive and ... a pair of hands .
16 comments
Feb 17, 2010. 3:14 AMkev88 says:
what if i remove the toroid? will it still works.
Feb 19, 2010. 12:58 PMkev88 says:
what i mean is to completely removed the toroid and boost the current with just the transistor
Jun 6, 2011. 9:15 PMifarhan1 says:
can i replace the led with something else?
Jun 10, 2011. 7:12 AMifarhan1 says:
if the voltage is not in DC, is it in AC? My idea is to connect the joule thief to my created earth battery to charge a cell phone that use voltage under 3volt. Can it be done? Please help me.... thanx
Jun 9, 2010. 1:06 PMmvj says:
Hi,I'm new to the electronics thing and I was wandering if I could use a LM317 transistor instead of the 2N3904, I live in S.A. and cant realy find a 2N3904. Can someone please direct me to site from which I can learn and understand more about electronics,tnx
May 9, 2010. 2:47 AMacmefixer says:
In step 3 I didn't see anything giving the thickness or length of the wire.  The wire and toroid core determine the frequency, which isn't important.  I've been experimenting with the cores I got from goldmine-elec.com for five for a dollar.  These are large and very high permeability. I wound it full of telephone wire, and the JT frequency was so low I could hear it with an earphone.  More info in my blog here.
May 7, 2010. 2:56 AMacmefixer says:
When you put multiple LEDs in series, the voltage adds up.  For blue or white LEDs it is about 3 volts per LED.  Some transistors have a maximum voltage of only 20 volts,so use caution and do not exceed the maximum voltage for the transistor.  Keep in mind that 6 series LEDs is over 18 volts.
I connect multiple LEDs in parallel and they all light up fine, as long as the LEDs are from the same maker and made about the same time.  The Joule Thief's pulsed output helps distribute the current evenly over all the LEDs.
Sep 21, 2009. 6:46 AMV-Man737 says:
How would a C9013 transistor do in this? I'd like to see a more comprehensive list of transistors that would work, just for those of us whose sources for components are broken childrens' toys.
Sep 21, 2009. 12:04 PMV-Man737 says:
Thanks, good to know! I'll let you know how it turns out for me.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:neumanngregor
