loading
Step 3: The Door and "Thingy"
This is also a 2 part step. It is one of the most vital parts of the machine. Part 1 is the door the holds the candy in the top chamber, and Part 2 is what pulls back the handle after you have had the desired amount of candy dispensed.
Part 1: Use some of your longer smooth pieces to make the shaft back to the door. After, make sure you cover you door in smooth pieces, as to make it so it slides back and forth easily. Make sure every thing is stuck together tightly.
Part 2: This is where you need your rubber band, pieces with holes in them and connecter pins. Mount 2 1x2 pieces in a flat 6x2, to brace the pieces with the rubber band. Next mount the 1x2 pieces with holes in them and have the connecter pins in them. You will also have to put the rubber band in the middle of them, but depending on the size of your rubber band, you will need to double or triple fold it. Make sure it cannot come out before continuing. Attach the Pieces that are next to each other to brace them further. After this is done, attach the whole thing together on the top with another 6x2 flat piece. Stretch the rubber band over to your lang connecter pin and connect the connecter pin in the sides of the 2 4x1 pieces with holes in them. Put a 3x2 pice on top to secure it.
After you have completed Parts 1&2, set your main body upside down and put the door in upside down. Attach the "thingy" to the main body, with the smaller part facing in. pull you door all of the way up to the "thingy" and attach the smaller part of the "thingy" to the door. After you do this, test it and make sure there are no kinks.
I have seen something like this before in a book I have called 'LEGO CRAZY ACTION contraptions by Don Rathjen and the editors of KLUTZ<br>
this was from a Lego book/kit thing that had instructions and some pieces..<br>i still got mine from Years back.. :P
Cool, but can you show it with candy so we can see how it works?
Sorry I didn't get back to you earlier. My computer won't let me post videos and here, but I posted the main picture to show how the candy comes out. Basically, you push in the handle and the candy falls into the bottom for you to retrieve.
and i'm a lego FAN you can also get on mln you go to lego .com and sighn up for free! i'm kunfumaster1183 ;)
my brother can do something like that!
I used to have a legobook with more or less the exact same design<br>
Ditto.
im a BIG lego builder but i would not have ever thought of that
Thank you
What type of candy is this designed for?<br> <br> L
This is mainly designed for M&amp;Ms and Reeses Pieces, although it could work also with Smarties, Bottlecaps, and the like.
OK cheers, &amp; happy Christmas.<br> <br> L
I've seen stuff like this before, good job!
Thank You!
I make these all the time! Cool tut, by the way.
Thanks!
About This Instructable
48,509views
78favorites
License:
Bio: I am a Senior in California. I love running, hacking things, and making all sorts of stuff, from cardboard contraptions to electronic circuits.
More by ncoleman2:How to Make a Square Wheel World Famous Chocolate Chip Cookies Knight Rider LED Circuit
Add instructable to:
