How to make a Longboard (Revised and updated)
This instructable is going to be a basic guide on how to make a longboard.
Since i can not  possibly cover everything, and also since a lot of the learning comes with experience, you will need to do some research and experimenting on your own. Building a longboard is not a simple task and it requires patience, hard work, and attention to detail.
Hopefully i can share with you what i know, and what has worked well for me, so that you too can start making boards for yourself, and maybe even friends.
If you are really new to this, you might not even know what longboarding is. If you have no idea what longboarding is, then i would refer to this instructable first: http://www.instructables.com/id/Longboarding-what-is-it/
Ok you want to build a longboard!
Here are a few things to keep in mind:
Longboard building is not cheap, but if you do put time, care, and effort into your boards they will last you a long time. Your first few boards will probably break as mine did, but once you get it down, you will have lots of boards to ride, and possibly sell. I would recommend starting out with a simple design and then move onto more complicated designs once you have board making down.
Please note: The instructions and techniques come from all different sites and i am just putting it all together into an instructable. I am not stealing the information, i am using what i know wand what knowledge others have shared with me.
Here is a good website to help you with building if you get stuck.
Silverfishlongboarding
Finally: *I am not responsible for any injuries, build boards and skate them at your own risk. Please always wear the proper safety gear when skating*
Step 1Constructing the press
Ok so before you can even make your longboard you are going to need to build a press. The press is what presses your wood sheets together, into a certain shape, to make a solid board. There are a few different types of presses, but i have narrowed it down to the ones that are the most effective.
The bolt press: (Cost $20 or more)
Bolt Press - This press uses bolts that you tighten down to put pressure on the board. It incorporates wooden ribs to make the shape of your board. This press takes a bit of time to build, but it is probably the cheapest and simplest. You will have to spend a bit of money to purchase the wood to build the press as well.
Vacuum bagging: (Cost $50 or more)
Air Press - This press you can buy online from Roarockit. You could also make your own if you know what you are doing, but i am unsure on how to go about making one. With this method you put your wood sheets in a vacuum bag that has a foam mold in it. When you suck all the air out, the wood forms to your foam mold. You can get a press from: http://www.roarockit.com/index.php
So for this instructable i am just going to show how to make the bolt press and not the vacuum bag. I would show you how to do both, but i no longer have my vacuum bag and if you are using the Roarockit vacuum press, they have instructions on how to use it when you buy the kit.
There are two different types of bolt presses. There is the basic plank press and then a ribbed press. The plank press is less complicated and simpler, and the ribbed press is more complicated and effective
So here is how to construct your bolt press(es):
Materials:
- Some 2x4s
- Bottom sheet of plywood (preferably 1/2inch to 1inch thick)
- 6 to 8 identical bolts - with nuts and washers (you DO NOT want the locking nuts)
- Screws to hold your press together
- Clamps
Assembly for press 1:
First figure out how long you want your press to be. I chose to have mine 4 feel long. (because i usually do not make boards longer than that)
Cut a single 2x4 to your press length (in my case 4 feet). Then cut 3 or 4 one foot sections of 2x4s. Assemble the one foot sections an equal distance away from each other perpendicular to the longer 2x4. Make sure the smaller one foot sections are on top of your longer 2x4. Screw it all together. See picture one for help.
Now to make the base.
Take your plywood sheet and cut it to be as long as your press (in my case 4 feet), and then cut it 1 1/2 feet wide. Next take two 2x4s and cut them to your press length (in my case 4 feet). Take those two 2x4s you just cut and screw them down onto your plywood base. Make sure you line these up so that there is less than 11 inches, but at least 10 inches between the two 2x4s. You want just enough room so that your baltic birch can sit comfortably with one inch of hang over on each of the 2x4s. Don't give it too much hang over, or you will block the bolts. See picture one and two for help.
Now line up your top and bottom sections that you have finished assembling. One they are lined up drill holes all the way through. Test to see if your bots all fit and the top and bottom line up properly. See picture 5 for help.
What this press is going to allow you to do, is have concave.
You will want your board to have a bit of concave. Concave is the curve in a board that locks your feet in when your riding. Too much concave an your board will be very uncomfortable. But concave is necessary to hold your board together. Because when your pressing wood, you need to have some kind of shape to it, or else it will be really flimsy and break. Also make sure you get the right length bolts, that fit all the way to the top, so you can screw them down.
Assembly for press 2 (more recommended):
This is basically the same except you use ribs to press the board instead of the pressure being on the single beam. This makes for a stronger more solid pressing. FINISH THIS SECTION BLAHHHH
358 comments
1-40 of 358next »
Feb 6, 2012. 4:48 AMtheAtalization says:
Hey I have a BAMBOO PLYWOODs to sale- I started to import 100% natural bamboo plywood straight from China especially for LONGBOARD DECK MAKING.
Contact me: bamboo.plywoods@gmail.com
Jan 19, 2012. 10:17 AMmir0k says:
Do you have any advice of proper adjusting trucks when you don't have a center line anymore? Thanks.
Nov 11, 2011. 12:36 AMsamdaman says:
i was wondering how many layers of wood and what thickness i would need to build longboard. im 6'1 and 225lb's
Dec 5, 2011. 4:16 PMjbergeron4 says:
you'll need 4 plys of 1/8 and you'll have to apply fiberglass.
Oct 22, 2011. 8:09 AMcfox9 says:
hey guys i need some info on building a long board. i am 175 pounds 5'8ft and i already know the design of my board, i just need to know what size of plywood(maple, oak, etc.). also how many sheets of plywood, and number of sheets of fiber glass. finally how long should my board be?
May 14, 2011. 3:12 PMmatthewkhoury75 says:
Ok, I am new to longboarding and am thinking of making one this summer. First off, I was thinking about making a foam press like this one http://www.instructables.com/id/How-to-Make-a-Longboard-Skateboard/step3/Glueing-Pressing/ Do you think this will be ok?
Next, I really have no clue what the demensions should be. I guess it will be 4 feet long, but how wide? I am probably going to make a design like the second picture on this page (Go Ride!). Lastly, I also have no clue what types of wheels or trucks to get. I am new and dont know which are good and bad, ect.
Aug 18, 2011. 2:38 PMawatkins4 says:
u shouldnt make a board longer than 45 inches
Oct 5, 2011. 2:39 PMtsabino says:
You best be trolling. A friend of mine has an 84 inch board and it's brilliant...
Sep 30, 2011. 12:13 PMpyoung4 says:
if your like 5 years old.... my board is 54 inches long. why should it be so short? answer: it shouldn't. Long longboards are easier to control downhill. short boards are more for boardwalk cruising where you have to dodge people a lot.
Aug 30, 2011. 9:43 PMunbentcrayfish says:
I've seen 1.5 meter longboards. (60in) you can make them as long as you want. Just make sure they are stiff enough.
Aug 28, 2011. 4:53 PMLuminousObject says:
You shouldn't give advice unless you know what you're talking about. What is your reason for not making a board longer than 45"?
Jun 21, 2011. 9:08 PMadambauman says:
i have a couple suggestions on hardware, the three most common trucks i think are bears(my fave), paris, and randalls. you can do your own research for what truck is best for you.
as far as wheels go, hawgs, abec11, orangatang, seismic, sector nine, etc. lots of wheels to choose from. wheels have a couple main differences. durometer(durometer is the hardness of the wheel),the higher the number the better for sliding. lower, the grippier. lots more to talk about.
bearings, i don't know much about.
Sep 28, 2011. 6:07 PMMaco13 says:
Where do you buy your birch? Is it a store or a website? I've got no stores near me and I can only find one website.
Sep 15, 2011. 11:55 AMdrummerkid678 says:
How may plys of birch should I use if I was going to build a 28 inch dropthrough and I wanted it to be pretty flexy? Thanks
Apr 30, 2011. 7:56 PMbenguit1 says:
am i okay if i take 4 sheet of 1/8 of oak and put 2 sheets of fiberglass or i need 6 sheet of 1/8 of oak and put just 1 sheet of fiber glass? (sorry for my english)
Aug 18, 2011. 2:39 PMawatkins4 says:
more than 4 sheets of fibreglass will make a way better board
Jun 25, 2011. 5:11 PMarobertson4 says:
hey will 3 layers of 1/8 inch be enough plus 2 layers of fiberglass? i weigh around 175
Aug 18, 2011. 2:36 PMawatkins4 says:
u need at least 5 layers wood and and 4layers fibreglass
im 90 pounds and i can easily bottom out a board with 4 layers of wood and 2 fibreglass
also
more fibreglass will give the board a livelier flex
for the best flex use over 8 layers of fibreglass with epoxy resin instead of polyester resin
ps dont buy automotive fibreglass
Aug 3, 2011. 10:45 PMwelliott2 says:
hey question what do you personally do the make the indentation where the wheels are.
Aug 3, 2011. 9:11 AMccook10 says:
How many sheets of wood do you usually use?
Jun 14, 2010. 5:46 PMchriswilliams805 says:
I have a question. I live in Santa Cruz CA, and I am having a hard time finding Maple or Baltic Burch up here that is not ply. Any suggestions on websites? I have yet to find any that are not on the east coast.
Aug 1, 2011. 3:03 PMjoshrocks98 says:
hey i live is sc too. go to aura woodworkers or whatever. they can order 1/8 baltic birch
Jan 16, 2011. 7:45 PMKomunity says:
Woodcraft.com
or
Rockler.com
Feb 24, 2011. 10:55 AMjinx52266 says:
I got a 5x5 sheet of baltic birch, how can I cut it?
Jul 16, 2011. 1:16 PMrcarson1 says:
Use a skilsaw.
Apr 24, 2011. 8:47 PMdunerider5555 says:
It would be easier to just lay weights on the wood with it elevated replicating the press force rather than blowing $20 on building one.
You are not going to be able to get a nice concave that way. The weights work well if you are making a rocker, type board.
Jul 6, 2011. 5:17 PMnkwok says:
the wood that i found at lowes doesnt have any filling inside, and they only have 1/4 in thickness im around 100 lbs if I use 2 sheets will it support my weight with a little bit of flex?
Jul 16, 2011. 1:14 PMrcarson1 says:
Well what type of wood is it?
Jul 16, 2011. 1:11 PMrcarson1 says:
After I put glue on and put the sheets in the press, will the press itself have enough pressure to keep the sheets glued together? or will i need calmps?
Jun 27, 2011. 10:48 AMskim1 says:
For grip tape, my friend used 3M safety walk tape (Anti Slip Tape) and he says it works better than normal grip tape, and its super cheap.
Just a suggestion
Jun 13, 2011. 8:39 AMkillermikeman says:
Why is it better to "glue" two sheets of wood together? what is wrong with one thicker one?
Jun 26, 2011. 8:14 AMmikemets05 says:
one thicker one will not bend in a press as well as two thinner sheets and when the glue dries between the thin ones it locks the curve in
May 27, 2011. 3:45 AMKryptonite says:
Is this design capable of taking a 'drop-through' mounting method?
Jun 6, 2011. 3:57 PMbturner5 says:
yes you just have to have the know how to make the hole for drop through and you can make it
Apr 29, 2011. 4:14 PMtscharrer says:
Hey i was wondering what kind of glue to use. What is the best? Also, I made a board out of 3 layers of 1/4 oak and it snapped with fiberglass on it. So I am going to make one with 3 layers of 1/4 Baltic Birch. Do you think 2 layers would be ok with two layers of fiberglass. Will it break? Have any of your baltic birch 2 layered boards ever broken? Thanks
Apr 27, 2011. 9:17 AMStyrre says:
Hi!
I thought about creating a drop-through-deck but will the board be able to bear my weight (80 kg) well enough? I believe that the part of the board where the trucks will be attached must be a little less strong compared to an ordinary deck, am I right? How thick must the deck be around the trucks to not break?
I've tried to find the answers on Google but I haven't, maybe you could help me?
I'm really glad for any answer!
Thanx!
Apr 4, 2011. 11:32 AMjgrennan says:
Where did you find the sheets of baltic birch in the picture above?
Apr 1, 2011. 8:11 PMlongboardrider101 says:
What I Am Trying Figure Out. When you said that you want two two by fours on each side of the press. Have less then Eleven Inches But More Then 10. Well those two boards on the side of your picture Five. That you said were two by fours. Are like tiny pieces of wood that are not two by fours. Is this correct. Or I Wrong.
1-40 of 358next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
67
Author:TeacherOfTheWays
Im back.
