How to make a Longboard (Revised and updated) by TeacherOfTheWays
Featured
This instructable is going to be a basic guide on how to make a longboard.
Since i can not  possibly cover everything, and also since a lot of the learning comes with experience, you will need to do some research and experimenting on your own. Building a longboard is not a simple task and it requires patience, hard work, and attention to detail.
Hopefully i can share with you what i know, and what has worked well for me, so that you too can start making boards for yourself, and maybe even friends.
If you are really new to this, you might not even know what longboarding is. If you have no idea what longboarding is, then i would refer to this instructable first: http://www.instructables.com/id/Longboarding-what-is-it/
Ok you want to build a longboard!
Here are a few things to keep in mind:
Longboard building is not cheap, but if you do put time, care, and effort into your boards they will last you a long time. Your first few boards will probably break as mine did, but once you get it down, you will have lots of boards to ride, and possibly sell. I would recommend starting out with a simple design and then move onto more complicated designs once you have board making down.
Please note: The instructions and techniques come from all different sites and i am just putting it all together into an instructable. I am not stealing the information, i am using what i know wand what knowledge others have shared with me.
Here is a good website to help you with building if you get stuck.
Silverfishlongboarding
Finally: *I am not responsible for any injuries, build boards and skate them at your own risk. Please always wear the proper safety gear when skating*
Step 1: Constructing the press
Ok so before you can even make your longboard you are going to need to build a press. The press is what presses your wood sheets together, into a certain shape, to make a solid board. There are a few different types of presses, but i have narrowed it down to the ones that are the most effective.
The bolt press: (Cost $20 or more)
Bolt Press - This press uses bolts that you tighten down to put pressure on the board. It incorporates wooden ribs to make the shape of your board. This press takes a bit of time to build, but it is probably the cheapest and simplest. You will have to spend a bit of money to purchase the wood to build the press as well.
Vacuum bagging: (Cost $50 or more)
Air Press - This press you can buy online from Roarockit. You could also make your own if you know what you are doing, but i am unsure on how to go about making one. With this method you put your wood sheets in a vacuum bag that has a foam mold in it. When you suck all the air out, the wood forms to your foam mold. You can get a press from: http://www.roarockit.com/index.php
So for this instructable i am just going to show how to make the bolt press and not the vacuum bag. I would show you how to do both, but i no longer have my vacuum bag and if you are using the Roarockit vacuum press, they have instructions on how to use it when you buy the kit.
There are two different types of bolt presses. There is the basic plank press and then a ribbed press. The plank press is less complicated and simpler, and the ribbed press is more complicated and effective
So here is how to construct your bolt press(es):
Materials:
- Some 2x4s
- Bottom sheet of plywood (preferably 1/2inch to 1inch thick)
- 6 to 8 identical bolts - with nuts and washers (you DO NOT want the locking nuts)
- Screws to hold your press together
- Clamps
Assembly for press 1:
First figure out how long you want your press to be. I chose to have mine 4 feel long. (because i usually do not make boards longer than that)
Cut a single 2x4 to your press length (in my case 4 feet). Then cut 3 or 4 one foot sections of 2x4s. Assemble the one foot sections an equal distance away from each other perpendicular to the longer 2x4. Make sure the smaller one foot sections are on top of your longer 2x4. Screw it all together. See picture one for help.
Now to make the base.
Take your plywood sheet and cut it to be as long as your press (in my case 4 feet), and then cut it 1 1/2 feet wide. Next take two 2x4s and cut them to your press length (in my case 4 feet). Take those two 2x4s you just cut and screw them down onto your plywood base. Make sure you line these up so that there is less than 11 inches, but at least 10 inches between the two 2x4s. You want just enough room so that your baltic birch can sit comfortably with one inch of hang over on each of the 2x4s. Don't give it too much hang over, or you will block the bolts. See picture one and two for help.
Now line up your top and bottom sections that you have finished assembling. One they are lined up drill holes all the way through. Test to see if your bots all fit and the top and bottom line up properly. See picture 5 for help.
What this press is going to allow you to do, is have concave.
You will want your board to have a bit of concave. Concave is the curve in a board that locks your feet in when your riding. Too much concave an your board will be very uncomfortable. But concave is necessary to hold your board together. Because when your pressing wood, you need to have some kind of shape to it, or else it will be really flimsy and break. Also make sure you get the right length bolts, that fit all the way to the top, so you can screw them down.
Assembly for press 2 (more recommended):
This is basically the same except you use ribs to press the board instead of the pressure being on the single beam. This makes for a stronger more solid pressing. FINISH THIS SECTION BLAHHHH
Step 2: Choosing your wood
Now you are going to need to find some wood to make into a longboard!
First off I would like to say that I have only used baltic birch, but it has worked well for me and so I have stuck with it. You can always try using different types of woods. Some are stronger than others and this can work to your advantage.
Where do i buy wood from?
Good question.
Hopefully near where you live there is a local wood store. If you are unsure look online to find if there is one near you.
If you do not have a wood store in your town, then you can always look online. This is a bit more time consuming and expensive, but you gotta do what you gotta do.
Finally, your probably saying "cant i just go to HomeDepot or Lowes and get wood from there?".........you can, but be vary cautious as the wood at HomeDepot and Lowes is plywood, which means it has filler in the middle of the wood instead of wood. (confusing right) This means it is not as strong and breaks very easily. I strongly recommend staying away from HomeDepot and Lowes, go to an actual wood store instead.
What types of wood are good to use?
Here are the two most popular woods that people use:
Maple - Stronger more cleaner look, more expensive, good for stiff downhill boards
Baltic Birch - Weaker less clean look, less expensive, better for flexy carving and crusing boards (what i use) also good for downhill boards
What thickness should i get?
Ideally you want your board to be about a 1/2inch thick or less. But it all depends on what kind of board you are making. If you want a downhill board then you will probably want it to be stiffer, requiring more sheets than a carving or cruising board.
There are two different types of thicknesses that are most often used:
1/4th inch thick - if you are making a board using this thickness, use two sheets, this makes for a flexier board that is a bit weaker than the 1/8th inch thick.
1/8th inch thick - if you are making a board using this thickness, use four sheets, this makes for a stronger board that can still be flexy, but more solid than the 1/4th inch thick.
Cutting the wood:
So at my local store the baltic birch usually comes in a 5x5 sheet for about $30. This is about average for most wood stores. (I think) You should cut the sheet into foot wide sections, and a little longer than you want your board to be. So for example, if i wanted to make a board that was 42 inches long. I would cut a one foot by 46 inch section (leaving 2 inches of room on each side). Always remember to cut with the grain instead of against, this strengthens your board ALOT.
Step 3: Drawing the template
The template:
First you are going to want to make a template of your board shape.
Do this by taping a few sheets of paper together and then fold it all in half. Then draw half of your board. Once you have done that, fold the paper in half and trace over the lines you have drawn, this will transfer the graphite over to the other side making the two sides of your template identical! Darken the lines so you can see them better.
Once you are happy with your shape carefully cut out the template.
Make sure your template design is not bigger than the width and length of your press
Step 4: Pressing time!
Pressing your board:
Time to press those sheets of wood into a board!
First off you want to outline your template onto one of the sheets of wood.
Draw a center line on one of the wood sheets.
Place your template on the center when outlining onto the wood.
You can tape it down so it does not move.
Trace your outline onto the sheet. (see picture 1)
Materials:
(see picture 2)
First off lay out all your materials, here is a list of materials you will need:
- Tiebond 1, 2, or 3 Wood Glue (I do not recommend Gorilla Glue)
- Paintbrush for spreading glue, roller also works
- Sandpaper or a sander
- Drill
- Jigsaw
- Pencil
- Tape measure
- Clamps
- Trucks and wheels and hardware
- Griptape
- Spray paint (if you want)
Gluing:
Set down a blanket or something when you are gluing and put your sheets of wood on top.
Glue the bottom sheet nice and evenly, spreading it with the brush/roller.
Remember its always better to use more glue than less.
Do this in a timely fashion as time is of the essence, you do not want your glue to dry on you! *Some glues dry faster than others*
Once you are done gluing your sheets, put the top sheet with the design on the very outside so you can see it. (see picture 3)
Pressing:
Put the glued sheets into your press making sure they are where they should be. Tighten down your bolts until you get the desired amount of concave (see press 1 option on page one)
Once the sheets are in the press tightened down, you can add some clamps to the areas lacking in pressure. Wipe off extra glue from your board so it does not get in the press.
Finally, leave your sheets overnight (at least 24 hours) and then take it out.
Your board should have concave too it, and it should be nice and solid.
Step 5: Cutting, Sanding, Drilling
So the next day pop that baby out.
You will see the concave it now has, and you will see your design on top.
Don't be tempted to step on it, because it will give you a false reading of how flexy your board is. You will want to cut it out to know how it really feels.
Cutting:
So grab your jigsaw and start cutting.
Follow the line that you have drawn on the top piece of wood and try and cut it out nice and neatly. Once you have cut that out, feel free to do a stress test by putting some wood blocks or something where the trucks will go and standing on it. Dont do anything too crazy, don't want to break that board! Hopefully you are happy with how it feels.
Sanding:
Once it is cut out, grab your sander and sand the edges down until they are nice and smooth. If you go from rough sandpaper to smooth sandpaper it makes it very smooth
Feel free to sand wherever else your board is a bit rough.
Drilling:
So now you have your board all cut out and sanded smooth.
You should still have that center line on your board where you drew your template.
If you dont have that line, make one.
Grab the trucks you are going to use on your board, and line then up on the center line of your board, and place them depending on how much nose and tail you want. So if i wanted 2 inches of nose and tail, i would put the trucks 2 inches away from the nose and tail. Mark the holes down very carefully, you don't want to be off. You can use a yardstick to line up the trucks straight. When drilling holes, if you don't want it to splinter, go slowly, and start using a small drill bit and then use the bigger one.
You don't want your board going all crooked, it can be dangerous at high speeds, so try to drill the holes as straight as possible. This helps if you have a drill press.
Once you have drilled the holes, line the trucks back up and see if they line up properly.
If they don't try re-drilling.
Step 6: Finishing touches
You are almost done!
You can either leave your board blank or paint it. For your first board you may want to leave it blank, as it may break, and all your hard painting will be ruined.
But if you do want to paint it here is how.
Painting:
You are going to need some sand paper and spray paint.
Regular paint works too (like the stuff that comes in big tin cans)
Grab your board and take it outside, put it on a desk or sheet or something that will not get ruined when your painting. Spray pant that bad boy all over.
Take breaks and let it dry a bit in between coats.
Always wear a respirator and goggles when spray painting.
Then leave it overnight until it is fully dry. The next day, sand it with your soft grit sandpaper on top and bottom. Be careful to not push too hard, you are just trying to smooth it out, not take away the paint you have just done.
Clear Coating:
If you want to do a clear coat, then do this after you paint.
Just get your clear coat and brush it (or spray it) on. Apply at least 5 or so layers of clear coat, letting the previous one dry before you do the next.
This will let your board have a shiny, protective coating.
Gripping:
Go buy some grip tape!
Now you can apply your grip.
Take your grip and peel it off the backing. Stick it on the part of your board where you want grip, you can also make designs if you want to. Roll it down with a skate wheel to smooth out any air bubbles. Then sand the edges down with a file where the grip hangs over, until it has a kind of while outline. Finally cut it with a razor blade and try to keep it as clean as possible. (see pictures 2-5)
Step 7: Go ride!
Your done building your longboard! Set it up with trucks and wheels and go ride!
Show it off to all your friends!  Remember to skate safe, and wear all your safety gear!
If you have any questions or need help send me a message or leave a comment!
Here is a video of me going pretty fast on my homemade board!
http://www.youtube.com/watch?v=x8BbuS8JahQ
Related Links:
Toothless longboards
This site sells vacuum presses that are very simple and affordable:
Roarockit Longboards
The pictures below are of a few of the longboards i have made.
1-40 of 374Next »
GDADZGSONS says: Mar 29, 2013. 3:21 PM
Very sorry about that. It is very annoying.
GDADZGSONS says: Mar 29, 2013. 1:39 PM
Sorry about that computer went haywaire:[
GDADZGSONS says: Mar 29, 2013. 1:38 PM
Are you on silverfish longboarding?
GDADZGSONS says: Mar 15, 2013. 2:44 PM
What is the name of your board design? {If commercially available}
lauti2000 says: Jan 7, 2013. 5:12 PM
i have been wanting to make a longboard but dont know what typer of trucks bearings and wheels to get do you have any suggestions
Allthegoodnamesaregone says: Jan 18, 2013. 5:29 PM
Randalls or Paris 180s. Depends on what sort of riding you want to do.
Allthegoodnamesaregone says: Jan 18, 2013. 5:28 PM
Very nice instructable. Well described steps.
teach me cool stuff says: Nov 28, 2012. 1:54 PM
if i were to not use fiberglass and just birch, how many layers of 1/4 would i need? im 180
arobertson4 says: Jun 25, 2011. 5:11 PM
hey will 3 layers of 1/8 inch be enough plus 2 layers of fiberglass? i weigh around 175
awatkins4 says: Aug 18, 2011. 2:36 PM
u need at least 5 layers wood and and 4layers fibreglass
im 90 pounds and i can easily bottom out a board with 4 layers of wood and 2 fibreglass
also
more fibreglass will give the board a livelier flex
for the best flex use over 8 layers of fibreglass with epoxy resin instead of polyester resin
ps dont buy automotive fibreglass
midnite17 says: Oct 23, 2012. 9:04 AM
8 layers of fiberglass? that would make the board rock solid, and very uncomfortable to ride.
Maco13 says: Sep 28, 2011. 6:07 PM
Where do you buy your birch? Is it a store or a website? I've got no stores near me and I can only find one website.
midnite17 says: Oct 23, 2012. 9:02 AM
the aforementioned website www.roarockit.com sells all kinds of build kits for longboards and skateboards, in addition to all necessities for building. word of advice though, look elsewhere for your Titebond III glue. Amazon has a great deal on it.
samtheman268 says: Feb 19, 2012. 6:04 AM
Where about are you from? If your in the UK most timber companies sell birch plywood at various thickness.
Ne1410is says: Apr 4, 2012. 12:13 AM
Do you put arches in your boards
drummerkid678 says: Sep 15, 2011. 11:55 AM
How may plys of birch should I use if I was going to build a 28 inch dropthrough and I wanted it to be pretty flexy? Thanks
samtheman268 says: Feb 19, 2012. 6:06 AM
theAtalization says: Feb 6, 2012. 4:48 AM
Hey I have a BAMBOO PLYWOODs to sale- I started to import 100% natural bamboo plywood straight from China especially for LONGBOARD DECK MAKING.
Contact me: bamboo.plywoods@gmail.com
mir0k says: Jan 19, 2012. 10:17 AM
Do you have any advice of proper adjusting trucks when you don't have a center line anymore? Thanks.
samdaman says: Nov 11, 2011. 12:36 AM
i was wondering how many layers of wood and what thickness i would need to build longboard. im 6'1 and 225lb's
jbergeron4 says: Dec 5, 2011. 4:16 PM
you'll need 4 plys of 1/8 and you'll have to apply fiberglass.
cfox9 says: Oct 22, 2011. 8:09 AM
hey guys i need some info on building a long board. i am 175 pounds 5'8ft and i already know the design of my board, i just need to know what size of plywood(maple, oak, etc.). also how many sheets of plywood, and number of sheets of fiber glass. finally how long should my board be?
matthewkhoury75 says: May 14, 2011. 3:12 PM
Ok, I am new to longboarding and am thinking of making one this summer. First off, I was thinking about making a foam press like this one http://www.instructables.com/id/How-to-Make-a-Longboard-Skateboard/step3/Glueing-Pressing/ Do you think this will be ok?
Next, I really have no clue what the demensions should be. I guess it will be 4 feet long, but how wide? I am probably going to make a design like the second picture on this page (Go Ride!). Lastly, I also have no clue what types of wheels or trucks to get. I am new and dont know which are good and bad, ect.
awatkins4 says: Aug 18, 2011. 2:38 PM
u shouldnt make a board longer than 45 inches
TheBlueMelon says: Oct 5, 2011. 2:39 PM
You best be trolling. A friend of mine has an 84 inch board and it's brilliant...
pyoung4 says: Sep 30, 2011. 12:13 PM
if your like 5 years old.... my board is 54 inches long. why should it be so short? answer: it shouldn't. Long longboards are easier to control downhill. short boards are more for boardwalk cruising where you have to dodge people a lot.
unbentcrayfish says: Aug 30, 2011. 9:43 PM
I've seen 1.5 meter longboards. (60in) you can make them as long as you want. Just make sure they are stiff enough.
LuminousObject says: Aug 28, 2011. 4:53 PM
You shouldn't give advice unless you know what you're talking about. What is your reason for not making a board longer than 45"?
adambauman says: Jun 21, 2011. 9:08 PM
i have a couple suggestions on hardware, the three most common trucks i think are bears(my fave), paris, and randalls. you can do your own research for what truck is best for you.
as far as wheels go, hawgs, abec11, orangatang, seismic, sector nine, etc. lots of wheels to choose from. wheels have a couple main differences. durometer(durometer is the hardness of the wheel),the higher the number the better for sliding. lower, the grippier. lots more to talk about.
bearings, i don't know much about.
benguit1 says: Apr 30, 2011. 7:56 PM
am i okay if i take 4 sheet of 1/8 of oak and put 2 sheets of fiberglass or i need 6 sheet of 1/8 of oak and put just 1 sheet of fiber glass? (sorry for my english)
awatkins4 says: Aug 18, 2011. 2:39 PM
more than 4 sheets of fibreglass will make a way better board
welliott2 says: Aug 3, 2011. 10:45 PM
hey question what do you personally do the make the indentation where the wheels are.
ccook10 says: Aug 3, 2011. 9:11 AM
How many sheets of wood do you usually use?
chriswilliams805 says: Jun 14, 2010. 5:46 PM
I have a question. I live in Santa Cruz CA, and I am having a hard time finding Maple or Baltic Burch up here that is not ply. Any suggestions on websites? I have yet to find any that are not on the east coast.
joshrocks98 says: Aug 1, 2011. 3:03 PM
hey i live is sc too. go to aura woodworkers or whatever. they can order 1/8 baltic birch
Komunity says: Jan 16, 2011. 7:45 PM
Woodcraft.com
or
Rockler.com
TeacherOfTheWays (author) says: Jun 16, 2010. 11:43 PM
I am really unsure. You might just have to work with what you got and see how it turns out.
1-40 of 374Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
