3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a Longboard (Revised and updated)
Step 6Finishing touches
Finishing touches
You are almost done!
You can either leave your board blank or paint it. For your first board you may want to leave it blank, as it may break, and all your hard painting will be ruined.
But if you do want to paint it here is how.
Painting:
You are going to need some sand paper and spray paint.
Regular paint works too (like the stuff that comes in big tin cans)
Grab your board and take it outside, put it on a desk or sheet or something that will not get ruined when your painting. Spray pant that bad boy all over.
Take breaks and let it dry a bit in between coats.
Always wear a respirator and goggles when spray painting.
Then leave it overnight until it is fully dry. The next day, sand it with your soft grit sandpaper on top and bottom. Be careful to not push too hard, you are just trying to smooth it out, not take away the paint you have just done.
Clear Coating:
If you want to do a clear coat, then do this after you paint.
Just get your clear coat and brush it (or spray it) on. Apply at least 5 or so layers of clear coat, letting the previous one dry before you do the next.
This will let your board have a shiny, protective coating.
Gripping:
Go buy some grip tape!
Now you can apply your grip.
Take your grip and peel it off the backing. Stick it on the part of your board where you want grip, you can also make designs if you want to. Roll it down with a skate wheel to smooth out any air bubbles. Then sand the edges down with a file where the grip hangs over, until it has a kind of while outline. Finally cut it with a razor blade and try to keep it as clean as possible. (see pictures 2-5)
10 comments
Dec 19, 2010. 6:06 PMStormed Wolf says:
Instead of buying grip tape (and i have no idea if this would work, just my creative side speaking) could you, 15-20 minutes after add your first coat of clear coat (or until it's tacky) sprinkle some fine white sand onto the clear coat, and have it stick, but after that, finish adding the other 3-4 coats? Because I like to see something on the top of my board, and if i had done a pinstripe/ graphic on the top, or some fancy thing with some wood laminate, I would want to see my work.
Once again, no idea if this would work, it seems practical, but I'm not sure.
I love longboarding, the only problem is that all the coordination i have is in my hands, so i won't be doing any tricks anytime soon. Plus most of the boards i like tend to be a little out of price range...
Feb 6, 2011. 11:07 PMjulian24 says:
try using castor sugar or crushed glass on a resin.
some people use castor sugar on windsurf boards and it works well, except its more for barefoot riding.
the crushed glass is savage, but will last forever, just be careful about how coarse it is or u will rip up the tread on ur shoes.
Jan 16, 2011. 9:31 PMman ray says:
They have "see-thru" grip tape. :)
Feb 6, 2011. 11:08 PMjulian24 says:
this is also a good option
Dec 21, 2010. 6:58 AMtopgun305 says:
I believe that you could put sand on the board as an alternative to grip tape. I think it makes more sense to only have one coat on top of the sand, because (especially with "fine" sand) you might end up covering your board in sand and then smoothing it out with the clear coats, meaning you wasted time and a few handfuls of sand.
Worst case: just put tape on top of your sandy monster. Haha.
Dec 21, 2010. 12:30 PMStormed Wolf says:
Lol.
I guess fine sand isn't really what i meant to say, I don't want the stuff that you find in hourglasses, but no too coarse that I have to hit the grains with a hammer 37 times just to get the consistency that I want.
I'm not too into the sand terminology, but the sand you might buy for a kids sandbox or just sand you can find on any old riverbank.
I can see why you might only want one coat on top of the sand, but thanks for making me seem like I'm not completely off-base.
Apr 28, 2011. 12:11 PMessgeebee says:
Check out coarse grade sandblasting sand, I think around the 60 grit mark. (http://www.princessauto.com/workshop/air/sandblasting/sandblasting-accessories/8200552-greenblast-crushed-glass)
I used that, coupled with a MinWax Polycrylic applied with a spray gun on mine - sprayed a light coat, sprinkled, sprayed, sprinkled where I missed, sprayed x 6...
Turned out nice and smooth, semi-gloss finish, been riding it for 2.5 years, and it's finally needing a touchup this year. I don't ride barefoot, and it didn't destroy my shoes in any way (even my old Cons...)
The 10Kg bag of glass was under $10, the poly was about $13, bonus, the glass was made from recycled glass.
The only thing I'd look at changing is the latex-based poly - I think pinholes/missed spots may sightly contribute to the loss of grip over the years....
The only drawback in the re-application is if you had a custom painted design on top (I just have green-stained wood) - I imagine that you'd need to scrape and sand carefully, as paint remover/stripper would remove the design ;)
Dec 21, 2010. 9:29 PMtopgun305 says:
Haha. I'm not exactly a sand expert either. Let me know how it works for you though, I'm working on a board now.
Dec 22, 2010. 1:40 PMStormed Wolf says:
I'm about to start working on one, I've got most of the things i need except a press and one more sheet of wood (i'm using 1/8 in. Maple, cutting two sheets in half to make 4 layers).
Dec 23, 2010. 7:46 AMtopgun305 says:
I am so jealous of you. I'm the kind of person to experiment, and I would have loved to try something besides the super-common birch, but I can't find a supplier anywhere. I'm in northeast Florida, and the only local place doesn't have anything close to the size I need (only 2 or 3" wide strips)...
Dec 23, 2010. 8:55 PMStormed Wolf says:
I had to order mine from a specialty store. My local store only had maple as plywood and pre-made cabinets and flooring.
Jan 16, 2011. 5:58 PMKomunity says:
Dear God that deck look SEXY
Oct 12, 2010. 1:14 PMAppollo64 says:
Where can you buy grip tape at?
Oct 12, 2010. 6:39 PMNinjanator says:
princes auto! (my favorite store
May 21, 2010. 9:02 PMshopatross says:
is a concave nessary for a shortboard as in one like 24 inches long?
Sep 26, 2009. 8:40 PMjbharrison says:
thats a good lookin board
Jun 11, 2009. 5:46 PMbuildingstuffisfun says:
thats B-E-A-S-T!!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
68
Author:TeacherOfTheWays
Im back.
