Step 6: Boldly Solder until you're Older!
Once you have measured the distance, cut cables to length (stripping an old USB cable is perfect for our cable requirements; thin, flexible and in the correct colours!) and solder them to the top of the pins.
Solder the PWR cable to one leg of a normally-open tactile switch. Solder the other leg to GND. Check the resistance using a Multimeter (should give a reading of "0" when the switch is closed), and then plug the connector into the motherboard. Plug the power or a battery into the Macbook, and then press the tactile switch. If your soldering is good, your Macbook-tablet-mongrel should come to life!
Now switch everything off, disconnect the power, disconnect the keyboard connector and fit the USB D+, D-, 5V pins into the connector. USB GND will be soldered to the GND leg of the tactile switch. This is to avoid unnecessary strain on the connector pin.
The other ends of the USB cables can now be soldered to the USB cable of a small USB hub. I used a four-port hub from Trust, which I stripped and removed three of the ports.
This is so I can have:
-One right-hand side USB port
-An internal bluetooth module (an old Belkin model I had lying around)
-An internal SD card reader (I use this so much on my Macbook Pro that I wish the older Macbooks had one fitted as standard!)
-An internal 3G/HSDPA+ modem (a Huawei E3131, unlocked. Around £15 from eBay)
To see the pinouts, please go to this website: http://pinoutsguide.com/Inputs/apple_macbook_keyboard_pinout.shtml
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
