How to make a Macchiato
A macchiato is a beautiful, and tasty scientific drink.
It consists of layers of Chocolate, foam, milk, and coffee. And with the right tools and proper techniques, they are very easy to make.
I have separated this instructables into several steps. Grinding Tamping and Pouring, Foaming, and Layering. Each step needs proper techniques and practice to do it successfully.
For this you will need:
Espresso Machine
Espresso Cups
Coffee Beans
Coffee Grinder
Thermometer
Milk
Chocolate Sauce
Tamper
Cold Milk Frothing Pitcher
Glass Cup
Here's the finished product
Step 1Grinding, Tamping, Pouring.
Grinding:
Ideally you would grind your coffee with a bur grinder, but those can be very expensive, and most people don't have access to one so I will teach you how to use a blade grinder.
Coffee is freshest immediately after it is ground. After grinding coffee beans, the oils that were protected inside the bean are exposed to the air which oxidizes and stales the coffee. This occurs immediately after coffee grinding so it is important to tamp and extract the espresso as quickly as possible. The coffee grinder should be ran for 15-20 seconds every time a shot is desired so that only freshly ground coffee is used, for this reason it is not recommended to use pre-ground.
Tamping:
When your tamping the goal is to make a pellet of coffee that the the hot water from the espresso machine will penetrate evenly. Since the water from the espresso machine is under pressure, the espresso pellet must be hard and evenly tamped. Once your done grinding, put the ground coffee into you filter, use 2.5 to 3 teaspoons for a double shot.
Put the filled coffee filter on a sturdy surface, and take your coffee tamper and place it on top of the coffee in the filter. It should fit snugly into the top of the filter. If the tamper is too small, the coffee around the edges of the filter wont be compressed, and the water will flow through the grounds there, losing its flavor. Press straight down, applying even, firm pressure. You should aim for about 30 pounds of pressure. Push down, twisting slightly in one direction and lift straight up. The surface of the coffee should be smooth with no crumbs. Brush away any crumbs of coffee from around the edge of the filter and place the filter onto your espresso machine.
Pouring:
As a general rule of thumb, the darker the roast the shorter the extraction time should be. For example, espresso uses a Dark roast, and therefore the extraction time is quite short. The ideal rate-of-pour for espresso has the consistency of syrup, About 25-30 seconds.
To preserve the flavor of your coffee beans, you must protect them from moisture, light, and above all, air
30 comments
Feb 27, 2009. 11:20 PMFenimore says:
I have been employed at coffee shops/espresso bars, and coffee is something that I adore and take very seriously. So reading this, there's something that sticks out to me immediately. Though, one that I can not truly blame or feel anger towards the consumer society for. A macchiato (in the sense described above) is only what people commonly know it as in Starbucks, entrepreneur (mom and pop) style coffee shops do not serve the same. traditionally, a Macchiato is simple, and a rare order for Barista. A macchiato is a shot of espresso (usually a double or triple shot) with milk foam placed upon the top. Thus, the Italian meaning for macchiato, which is "to mark" My only point to clarify is that when ordering a macc. at home owned coffee shops, you must be specific. When a barista gives you a true macc and you are angry, please be angry at Starbucks for making the mistake of changing a beautiful and delicious drink in its entirety. For Barista's as a society. Thank you.
Feb 12, 2010. 1:11 PMcocodlicious says:
Don't frett, I too have been a barista and know your pain of having to remake drinks because Starbucks has an agenda to make your life as difficult as possible. There is a special place in hell for people like starbucks. Long Live the corner Coffee Shop.
Jun 14, 2009. 9:07 AMrawknexstuff says:
Who cares what it's called! For all I care, it could be called DINOSAUR POOP and as long as it is the same as in the instructable above, I'll drink it!
May 11, 2009. 12:01 PMlindsaytron says:
True story.
May 21, 2009. 5:07 AMjimsoda says:
Correct Fenimore. Growing up, I use to get a turbo from our local Italian barista. It is essentially a short cappuccino or a large macchiato. I ordered a turbo on a trip one time and got a triple espresso! My bad of course but funny how I assumed a turbo was universal. Starbucks gives coffee a bad name. Seattles Best was the best until Starbucks bought them. If you can't beat them, buy them and destroy them.
May 23, 2009. 12:35 AMFenimore says:
I conquer. I had to do a report on Starbucks and the history there of and I found that Seattles best was very legitimate "trustworthy." Yet, Starbucks (along with Tim Hortons,though not to such an extraneous extent.) have ruined coffee.
Sep 3, 2009. 1:21 PMuberchoob says:
Nice instructable! finished product looks great
I just wanted to add that we all need to calm down about the differences in similarly named beverages.
whether right or wrong, iMac is correct in saying it is a Macchiato, and yall are correct in saying it's not.
Though it may be better if it were called by it's regional name: "Starbucks / Californian Macchiato" , or with the traditional beverage: an "Italian Macchiato."
btw, I like alessiof76: "mocaccino" kinda makes sense
May 19, 2009. 12:59 PMalessiof76 says:
In Italy we call it "mocaccino" Great coffee machine! better than mine! Tip: for a great espresso use warm or hot coffee cup
May 8, 2009. 4:07 PMTraibhse says:
I agree with all above. I was a competitive barista for two years, and a macchiatto is generally served as a double in a demitasse and dolloped with foam (or art in some cases). The -only- place i know of that raped macchiatos everywhere is Starbucks with their 'caramel macchiato" bs, which is actually a caramel cafe latte. :-/ Oh the tragedy Starbucks has brought by its mass market commercialisation of such a beautiful thing. :'-(
Mar 29, 2009. 6:17 PMA.Mac says:
The problem is that people don't use the full name of coffee beverages. What most people call a latte should really be referred to as a caffe latte. Similarly with macchiatos, the drink that Starbucks serves is actually a caramel macchiato (Foamed milk marked with espresso and vanilla, then topped with a distinctive caramel pattern). That is what it is called on the website and probably also what it is listed as on the menu in the stores. Conversely at the high quality caffes here in town most serve an espresso macchiato (A shot of espresso marked with milk foam)
Mar 19, 2009. 1:19 PMchazzaplaya says:
I don't see the point in going to the effort of making real, freshly ground espresso to then go and ruin it with Hershey's syrup. That stuff makes me gag. With a machine like that your clearly a coffee purist so I'm surprised you do this but each to there own.
Mar 5, 2009. 12:59 AMAaron Compton says:
Cool post, I like the layers...I usually pour it so that it mixes. I have worked for may years as a barista, making awesome coffee for the masses, and the drink you make above would be more accurately called a moccachino. With layers. Fenimore is correct--a true macchiato is a demitasse cup with a shot or 3 of espresso, topped with a spot of froth. Alternatively you can 'stain' the espresso with a few drops of milk. In different places they call different coffees by different names--In Western Australia they serve a double shot in a small glass and top it with steamed milk and call that a macchiatto. Here in New Zealand we serve the same thing in a small cup and call it a flat white. I see starbucks is selling instant coffee now...
Sep 20, 2008. 1:33 PMbrawns214 says:
That's not a macchiato! This is a macchiato. What type of espresso machine are you using. It looks awesome!
Oct 6, 2008. 6:57 PMbethikus says:
Starbucks has ruined coffee. Macchiato is a four ounce drink. Only Starbucks can take a simple, delicate, and perfect thing and turn it into a 20 ounce glass of overheated non-frothy milk and four different syrups. Sigh...
Feb 20, 2009. 1:06 PMYerboogieman says:
My brother knows coffee left and right, i will only drink coffee he approves. He works at starbucks in safeway, if the coffee isn't right he gets splashed with it and presses a little button under the counter. :-D
Dec 28, 2008. 8:39 AMmrtentaclenun says:
That's not true at all, I happen to work at Starbucks and macchiato's are just shots of espresso and one scoop of foam. It's the customers who changed it to what you are describing.
Jul 21, 2009. 6:56 PMMesmerize says:
Agreed. The "caramel macchiato" phenomenon is actually a caramel café latté.
The word "macchiato" means "marked" in Italian - the espresso is pulled and then "marked" with steamed milk.
iMac needs to look at the picture more closely - that cup is 3-4oz. His is probably around 14oz. If the beverage is over 4oz, it is not a macchiato.
Also, his machine is gorgeous! I love lever machines :) there's something almost romantic about pulling a shot that way.
Dec 31, 2008. 9:37 AMfancypenguin845 says:
well watevr it is it looks goooood
Oct 19, 2008. 3:10 PMbjornm says:
I just want to second what many have already pointed out. What you are making is not a macchiato, a macchiato is an espresso with a dash of milk. I'm sure that even Starbucks know what a macchiato is. Anyway, nice guide - you should only change the title.
Dec 6, 2008. 7:32 PMnatnie says:
I agree! Maybe you can call it a "mochiato" :P
Oct 19, 2008. 3:56 PMwiresam says:
nescafe anyone?
Sep 22, 2008. 4:47 AMkimliatach says:
I have to agree with the other comments here it looks delicious but.... macchiato is Italian for stain (spotted according to Babel fish, lol) it should literally be a shot of espresso with a stain of heated milk in it, a teaspoon at most, yes it is served in a small espresso sized glass and yes the milk will float in a separate layer if added correctly, i would call that fine looking beverage a mocha.
Oct 3, 2008. 3:52 AMBellu says:
Latte is Italian for milk, which is why you got your warm glass of milk in Italy A macchia is Italian for stain, and in Italy a macchiato is an espresso "stained" with milk. I think what you amde looks for like a marocchino.
Sep 23, 2008. 3:55 PMkimliatach says:
yeah Starbucks has a lot to answer for, I make coffee for a living in Australia where people (including me) are very very fussy about espresso, and about two years ago people began asking for Long Macs thinking that a Mac was some big milky thing, confusion still reigns, As it is most Barristas now have to ask if the customer would like a real mac (wether short or long) or a starbucks mac. if you haven't tried it my favorite coffee at the moment is a piccilo: one shot espresso(30ml) one shot warm milk(30ml) in a small Mac glass. nice refreshing throw down coffee, great in summer. great instructable anyway mate.
Sep 21, 2008. 7:05 PMmwwdesign says:
That looks like a mochiatte! You should adjust the name (otherwise whingers like me will keep writing comments like mine!). A macchiato is a single espresso shot of coffee with a tiny bit of milk - then some froth dropped on top for identification, which in Italian it means 'the marked one'. Nice 'ible nonetheless.
Sep 20, 2008. 5:07 PMshooby says:
damn, that's a lot of work for a beverage.
Sep 20, 2008. 2:45 PMHDM528 says:
mabey
Sep 20, 2008. 11:38 AMfungus amungus says:
That's a huge macchiato! More like a latte macchiato. Could you put up your own original photo for the intro? It'll be an excuse to make one more, right?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:iMac
