It consists of layers of Chocolate, foam, milk, and coffee. And with the right tools and proper techniques, they are very easy to make.
I have separated this instructables into several steps. Grinding Tamping and Pouring, Foaming, and Layering. Each step needs proper techniques and practice to do it successfully.
For this you will need:
Espresso Machine
Espresso Cups
Coffee Beans
Coffee Grinder
Thermometer
Milk
Chocolate Sauce
Tamper
Cold Milk Frothing Pitcher
Glass Cup
Here's the finished product
Remove these ads by
Signing UpStep 1Grinding, Tamping, Pouring.
Ideally you would grind your coffee with a bur grinder, but those can be very expensive, and most people don't have access to one so I will teach you how to use a blade grinder.
Coffee is freshest immediately after it is ground. After grinding coffee beans, the oils that were protected inside the bean are exposed to the air which oxidizes and stales the coffee. This occurs immediately after coffee grinding so it is important to tamp and extract the espresso as quickly as possible. The coffee grinder should be ran for 15-20 seconds every time a shot is desired so that only freshly ground coffee is used, for this reason it is not recommended to use pre-ground.
Tamping:
When your tamping the goal is to make a pellet of coffee that the the hot water from the espresso machine will penetrate evenly. Since the water from the espresso machine is under pressure, the espresso pellet must be hard and evenly tamped. Once your done grinding, put the ground coffee into you filter, use 2.5 to 3 teaspoons for a double shot.
Put the filled coffee filter on a sturdy surface, and take your coffee tamper and place it on top of the coffee in the filter. It should fit snugly into the top of the filter. If the tamper is too small, the coffee around the edges of the filter wont be compressed, and the water will flow through the grounds there, losing its flavor. Press straight down, applying even, firm pressure. You should aim for about 30 pounds of pressure. Push down, twisting slightly in one direction and lift straight up. The surface of the coffee should be smooth with no crumbs. Brush away any crumbs of coffee from around the edge of the filter and place the filter onto your espresso machine.
Pouring:
As a general rule of thumb, the darker the roast the shorter the extraction time should be. For example, espresso uses a Dark roast, and therefore the extraction time is quite short. The ideal rate-of-pour for espresso has the consistency of syrup, About 25-30 seconds.
To preserve the flavor of your coffee beans, you must protect them from moisture, light, and above all, air
I just wanted to add that we all need to calm down about the differences in similarly named beverages.
whether right or wrong, iMac is correct in saying it is a Macchiato, and yall are correct in saying it's not.
Though it may be better if it were called by it's regional name: "Starbucks / Californian Macchiato" , or with the traditional beverage: an "Italian Macchiato."
btw, I like alessiof76: "mocaccino" kinda makes sense
The word "macchiato" means "marked" in Italian - the espresso is pulled and then "marked" with steamed milk.
iMac needs to look at the picture more closely - that cup is 3-4oz. His is probably around 14oz. If the beverage is over 4oz, it is not a macchiato.
Also, his machine is gorgeous! I love lever machines :) there's something almost romantic about pulling a shot that way.
