Introduction: How to Make a Makeblock Remote Control 2WD Robot
The Makeblock Remote Control 2WD Robot is a simple Makeblock robot. It is easy to build and control. We use a infrared remote control to control this robot.
If you have bought the starter kit with Me-BaseBoard go visit the instruction page below:
Me-Baseboard 2WD Robot
For more information, please visit Makeblock website here.
Getting Started
This instructable, How to make a Makeblock Remote Control 2WD Robot, will show you the step-by-step instructions on how to build a 2WD robot by Makeblock.
Now let's have some fun!
Step 1: Materials List
Materials List:
Mechanical Part List:
2 × Beam 0824-144
2 × Timing Pulley 90T
2 × Tyre 68.5×22mm
1 × Caster Wheel
2 × DC Motor-25 Bracket
1 × Plate 3×6
1 × Bracket P3
2 × Shaft Connector-4
4 × Screw M4×14
12 × Screw M4×8
4 × Countersunk Screw M3×8
2 × Headless Screw M3×5
1 × Nut M8
Electronic Modules List:
1 × Arduino
1 × Acrylic Box
1 × Me-BaseShield
1 × Battery Holder
1 × Acrylic Battery Bracket
2 × DC Motor-25
1 × Me Infrared Receiver Decode V2.0
1 × IR Remote Controller
1 × RJ11 Cable
Step 2: Build the Chassis of the Robot
Procedure:
Follow the pictured steps to build the chassis of the robot.
Step 3: Add Motors
Procedure:
Before add the motors on the chassis, you need build the two motors with motor brackets. Then install the Shaft Connect-4 on each motor.
In the end, add the motors on the chassis with 4 Screw M4×8.
Step 4: Attach Driving Wheels
Procedure:
Now attach Driving Wheels. The Driving Wheel is made by two parts, the Timing Pulley 90T and the Tyre 68.5×22mm.
So first install the Timing Pulley 90T to the motors.
Then attach the Tyre 68.5×22mm to each Timing Pulley 90T.
Step 5: Attach the Caster Wheel
Procedures:
Attach the Caster Wheel as the above pictures show. After doing that you may build a 2WD Robot without electronic parts.
Step 6: Add the Motor Wires
Procedures:
Now let's add the electronic parts to the 2WD Robot you have built.
Add teh motor wires to the motors as above pictures show.
Step 7: Add the Battery Holder
Procedures:
In this step, we'll add the Battery Holder to the bottom of the Robot by using 2 Plastic Rivet R4060.
Step 8: Add Arduino & Me-Baseshield
Procedures:
In this step, we'll add Arduino & Me-Baseshield to the top of the Robot by using 2 Plastic Rivet R4060.
Step 9: Add Me-Infrared Receiver Decode V2.0
Procedures:
After adding Arduino & Me-BaseShield we need add Me-Infrared Receiver Decode V2.0 to the Robot. Install Me-Infrared Receiver Decode V2.0 with two Screw M4×8 as above pictures show.
Step 10: Connect the Wires
Procedures:
It is easy to connect the wires now. The table above shows how to connect the motors and sensors to Me-BaseShield. After the connecting, we have made the Robot. The next step will show you how to upload the demo code and make the Robot run by using the remote controller.
