This all started when I learned that my friend Raouf Sarwari, who has his shop down the hall from me, has a laser cutter. Brooklyn is great for cross-pollinating ideas and skills with each other. Anyhow I have always liked models and thought it would be fun to build a wood wood shop. I spoke to Raouf and he agreed and we worked together to make one for the Crest Hardware Show.
http://cresthardwareartshow.com/
It is an annual art show that takes place in the midst of a running hardware store. The only requirement is that the art must be hardware related. This then is our how to make a mini band saw. Since then we saw that there was a laser contest and thought we should enter it.
Since working with the laser I cannot stop thinking of ways to use it, jigs, toys, tools the list keeps growing.
Remove these ads by
Signing UpStep 1: PDF Drawing
You can do what we did and mentally reverse engineer the band saw or you could measure an existing saw and draw it. Either way, draw out the parts to the band saw. We used Adobe Illustrator for the initial drawings then refined them for the laser cutter using Corel Draw. If you want to save yourself some time you can use the attached PDF file for yours.
While in the Photos you will see different colors they are not required in fact if you look at the last photo you can see Raouf and I built a mini wood shop and a mini plastic shop.
Separate the parts into thickness and color groups; you can see we put basic assemblies together as well
Next separate into cut groups by thickness. It may see a bit redundant but it helps to familiarize you with the parts.
In addition to cut lines in the drawing there are laser-etched areas. These serve as glue guides and also help shape some parts. They are cyan in the PDF.
001Bandsaw.pdf356 KB
Visit Our Store »
Go Pro Today »
Thanks!
Thanks for your interest.
The Kits in wood or plastic are $100.00 for one and $75.00 ea. for multiples.
We have more than just the bandsaw. we also have a tablesaw, work bench, drill press, lathe and soon others maybe a radial arm saw, buzz saw or .........?
Kits come with instructions but you will have to supply your own glue and hand tools.
Again thanks for asking.
The world of DIY is endless!
Thanks!
Sorry for the delay getting back to you. I would be willing to sell you a kit but I need to make sure that your really not thinking of using it as a tool. I don't think the tolerances are fine enough to be suitable for active cutting. You might want to look at proxxon mini tools if you want desktop power. You might be able to use a scroll say as well.
PS I couldn't tell if you were serious regarding using it. Let me me know if you're still interested
Voted!
Put it on my Blog, along with other good news for Gizmo Makers.
Keep it up!
http://faz-voce-mesmo.blogspot.pt/2012/09/um-makerbot-serio-um-robot-espanhol.html
Your response is precisely what made us want to make it, them.
To answer some questions,
Yes they do "work" meaning they spin and blades move appropriately, however we haven't put motors on them to fully test them. I am thinking they would need tiny bronze bushings etc if they were to really take on a workload.
If anyone wants to make the band saw and power it up please post an instructable on it.
There is no scale to it but the band saw was designed around the idea of a 14" .
It is actually about 8" tall, sorry i have never measured it.
Again thanks
