Introduction: How to Make a Mini Tube Dress
You must love this easy and flattering fit, works for every body type with the fitting elasticized waist.
You Will Need: Cotton fabric, elastic band, sewing machine, scissors, chalk.
On this video, besides from showing how to make the dress, I want show you guys a little bit more about my culture. May, is a very important month, of the Independence of my country, Paraguay, and we celebrate the 200 years of our liberty. I wanted to show a part of our history, so I did a tour of the renowned "Casa de la Independencia", where on the 14th and 15th of May, 1811 the Independence was born! In this house stands out Pictures that represent heroes of my country and you can also see crafts made by Franciscans and Jesuits.
Step 1: You Will Need.
Tela de algodón, banda elástica, la máquina de coser, tijeras, tizas.
Step 2: First Step
Picture #1: Measure on your body the width of the dress according to your size
Mide el ancho de lo que será el vestido acuerdo a tu medida.
Picture #2: Cut the excedent of the fabric
Corta la tela que resta.
Picture #3: Cut the other side.
Corta el otro lado
Picture #4 and Picture #5: Then sew both sides
Luego cose ambos lados
Step 3: Second Step
Picture #6: Do the hem on the top, pin the fabric
Haz el dobladillo y pincha la tela para luego poder coser.
Picture #7 and Picture #8: Sew in the shape of zig zag like you see in the picture
Debes coser en forma de zig zag como lo puedes ver en la foto.
Picture #9: Left a litlle space to put the elastic inside
Deja un espacio abierto para luego colocar el elástico adentro.
Picture #10: Measure the elastic, do not stretch it only has to be tight
Mide el elástico, al medirlo no lo estires debes ser justo nada más
Picture#11 and picture #12: Once you put the elastic inside, sew and close.
Una vez que hayas colocado el elástico, coselo y cierra.
Step 4: Third Step
Picture #13: Now for the fitting on the waist (you can also make it under the bust line). Measure the length os elastic you will need.
Ahora para dar forma en la cintura (también podría hacerlo por debajo del busto) Mide el largor de elástico que necesitará
Picture #14 and Picture #15: Now mark where the elastic need to be sew.
Ahora marca donde va ir el elástico para luego coserlo.
Picture #16: Sew directly on to the fabric
Cose directo el elástico sobre la tela
Picture #17 and Picture #18: For the last step do a little hem to give a finish touch.
Y como último paso haz un dobladillo en la parte inferior del vestido.
