Introduction: How to Make a Mount Rushmore Costume
Here, you can see me as Teddy Roosevelt, mostly because I wear glasses.
This costume is very simple to create, being mostly made of paper mache.
Step 1: Materials
- Newspapers, torn into 1-to-2 inch wide strips
- Water, semi-warm
- white school glue
- Flour
Frame / Rest of the Costume:
- Several scrap pieces of wood (I used some old baseboard molding)
- Chicken wire (hardware store, very cheap, 'cause you only need a few feet)
- Masking tape
- Spray paint (I used a grey primer, then some "rock texture" overlay to give depth)
- Old blue jeans - sacrified for shoulder straps
- Old bed sheet
- Staple gun and Staples
- Work gloves for molding the chicken wire
- Wire cutters (for trimming the chicken wire)
- Zip ties to attach masks to the chicken wire
- President Masks (I did Lincoln, Washington, and Jefferson since I wear glasses)
Jefferson: http://www.halloweenstore.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=16-02
Washington: http://www.halloweenstore.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=16-01
Lincoln: http://www.halloweenstore.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=16-04
- Grey face makeup (or clown white and some black, mix your own -- that's what I did)
- Grey hair spray
Step 2: Frame, Chicken Wire, Masks...
Using copious staples from the staple gun, attach the chicken wire to the wooden structure.
Put on your gloves and mold the chicken wire into the shape of a mountain.
Attach the masks to the chicken wire with zip ties.
Step 3: Mix Up the Paper Mache
I used a simple flour water recipe:
1 cup flour
1 1/2 to 2 cups water
1/2 cup white school glue
Mix well until smooth, sticky, but still fairly thin.
Put in the strips of newspaper one at a time, allow to soak for a few seconds. Then, as you pull out the strip of paper, squeegee off excess glue mixture with two of your fingers. Lay onto the chicken wire in overlapping and semi-random directions. DO NOT put all the strips in the same direction, the resulting paper mache will be weaker than if you randomize your strip pattern. Think plywood.
Apply a full coat of paper mache to the chicken wire, allow to dry for a couple hours. Apply a second, and third coat to thicken up the paper mache and give it strength.
Make sure to line the head hole opening very welll, so no chicken wire can stab you in the chin. Youch!
After your extra coats, allow the paper mache to dry for a couple days before painting. It should be hard and crusty when fully dry.
Step 4: Paint
I first covered the whole mountain with a grey spray paint primer, several thin coats.
Second, I came overtop with a stone texture spray paint, so the coloring wouldn't be flat. I left the masks as flat grey, as on the real Mount Rushmore, the faces are lighter, since they have been carved out. The flat grey gave this effect.
Step 5: Final Touches
I made my shoulder straps out of strips of old blue jeans -- just folded over, and sewed down the middle. Attached to the wooden frame with more staples from the staple gun.
I also wanted to cover the completely open back, so I again used the staple gun and an old bed sheet to create a clean/finished look on the back.
