Introduction: How to Make a Paracord Bracelet
How to make a Paracord Bracelet, here is instructions for the Cobra Paracord Bracelet, first get about 12 feet of paracord, and a paracord buckle. I use a Plastic side release buckle, but you can also make it with a Metal Paracord Buckle, you may have to modify it a little. Also get some smaller scissors and a lighter, if you have a paracord needle you can tuck in the ends so it looks better. Learn how to make a Paracord Bracelet with a Flatline or Tracer. Made this, try other Paracord Projects.
Step 1: How to Make a Paracord Bracelet , 1
Fold the paracord in two, attach to the buckles, then measure your paracord bracelet on your wrist for size.
Step 2: How to Make a Paracord Bracelet, 2
Bring the piece of paracord you want to be the center color, across the middle. Then bring the second piece of paracord, over the top of the first piece, then behind the paracord bracelet, and up through the hole made by the first piece of paracord. Make sure you get real 550 Paracord for you Paracord Projects.
Step 3: How to Make a Paracord Bracelet, 3
Now bring the first piece of paracord across the front, with the second piece of paracord over the top, around the back, and up through the hole made by the first piece of paracord. Pull it tight. Learn how to make a Paracord Bracelet with Mamba weave. Already made this try these other Paracord Bracelet Instructions.
Step 4: How to Make a Paracord Bracelet, 4
Continue the Paracord weave and remember to pull the Paracord Knots evenly each time.
Step 5: How to Make a Paracord Bracelet, 5
Once you braided all the way to the buckle, if you have a paracord needle, run the ends back into the braid, then cut the ends and melt the ends. If you don't have a paracord needle, just cut and melt the ends. Now your know How to make a Paracord Bracelet, Try making it with a Tracer, is a piece of micro paracord braided along the outer piece of paracord. Try more Paracord Procjects, or get a Custom Paracord Bracelet.
