loading
Step 5: Complete your first row
To complete the first row simply lighten the loops from RIGHT to LEFT
Once you get to the left you pull on the loop sticking out of the end on the right to tighten completely.
IMPORTANT NOTE
Because of all the loops we are putting in the cord it naturally becomes twisted. You need to un-twist the cord as you are tightening each loop. If you dont do this the finished weave will look  very messy.
Also do not over tighten your loops. If you do, it will distort the final weave pattern and again your belt will look a mess. Over tightening will also make it harder to pull through the next row of loops.
<p>The instructions are so clear for a complete beginner. Well Done!!</p>
<p>This was very helpfull!</p>
<p>you can also get a paracord cutter which actually melts the end as it cuts </p>
Thanks for the great instructions. This was my first paracord project, my old belt broke yesterday, so it seemed like a good time to try this. I ended up using a standard buckle from my old belt, so it remains adjustable. I finished the end with a D ring....Not sure why, I just liked it. It took many hours and I used about 86 feet of cord....I really hope I never have to unravel it.
<p>Great instructable! Really easy to understand.</p><p>If you are interested in two slight<strong> improvements</strong>, please see my instructable about &quot;Slatts rescue belt V2.0&quot;, that is adaptable in length and <strong>does not tend to skew to one side</strong>.</p><p>As regards measurements: A belt with six loops in a row made of 100ft. paracord is about 4cm wide and 120cm long (but that depends much on how much you tighten the cord).</p><p>With respect to sources for paracord, buckles of any kind, paracord needles and all the other good stuff: Give aliexpress.com a try, shipping take a while, but they sell reasonable quality for really low prices and you find easiely sellers who do not charge any shipping cost (meaning that they really sell you a 0.5$ buckle for only 0.5$ and send it to your home for free!).</p>
<p>Great instructions, I've been wanting a belt for hiking, this will be great! Haven't seen the whistle buckle but I'll do some checking on that one. Also love the Leatherman pouch you made.. looks like I'm going to be busy with the paracord again!</p>
<p>Great instructions. Thinking of adapting to make a 4&quot; wide guitar strap. I will need to have multiple colors (making for a friend). For survival purposes just fusing together the different colors would not be strong enough. What would you recommend?? Fusing and then stitching with micro cord?? Please advise. Thank you. and Thank you for the inspiration!!</p>
<p>I had thought about making a guitar strap after I made two belts with this knot pattern. But I think it would be too heavy. </p>
<p>You CAN splice paracord, though I have not found an easy way to do it. </p><p>1) Heat the edges of the cut outer shell so it doesn't fray. (don't over do it)<br>2) Fuse the inner cords and mash it into a tight cylinder.<br>3) Slide one side of the shell over the fuse (1/2 inch) then heat the shell slowly and compress it. (it needs to be tight and stiff about 1/2 inch long)<br>4)Now you can slide the other side over the first cord giving yourself at least 1 inch (this is the tough part)</p><p>You pinch the base of the stiff inner shell, push into the outer shell, pinch OS over the tip of the IS and slide the loose end of the OS over the cord of the IS (like a snake eating a rat, it's slow going and a little at a time) Now pinch the base of the IS again driving the OS onto it. Pinch the ON at the tip of the IS and... well you get it.</p><p>5) Once you have 1 inch heat the edge of the outer shell and crimp it onto the inner shell. When the two cords are pulled the outer shell works like a Chinese finger puzzle and wont let go.</p><p>It's not terribly flexible so it should be used in a straight area. I use this in the middle of my bracelets for multi color version.</p>
If i am a 40 waiat how much do i need? Also how do i reattach two 50 foot to make my 100 foot i had
I would use needle and thread
<p>Funny how &quot;Everything old is new again.&quot; 50 years ago this was called &quot;macrame'&quot;. Good idea and good instructable.</p>
<p>that was great. I did not like all the other methods because of the time to unravel it. This method works the way emergency gear should. Rapid deployment is the key factor.</p>
<p>Very nice, Stu! This is the first set of belt instructions I've seen that doesn't assume I already know how.</p>
<p>Can you finish it without a buckle on the end?</p>
Just wondering if anyone tried to do it with multi colors instead just one?
<p>Excellent tutorial!</p>
does anyone know what this weave is called?
<p>usually referred to as &quot;Slatt's Knot&quot; or Slatt's Rescue Belt&quot;</p>
The instructions and pictures helped me a lot.
Thanks for this tutorial. <br>In this picture unfortunately I can't see the 'few inches tail' you mentioned, though. Where is it? Mamy thanks.
Nevermind. It shows a few pics later. Thanks
Used a standard belt buckle. Started with 6 loops. Buckle works great with the pattern. I get compliments every time I wear it.
My son needed a belt.
<p>Will this weave work with a standard belt buckle like a braided leather belt? Thanks.</p>
<p>Just an FYI this isn't genuine paracord. If it was it would have a colored tracable cord running through it meant for identifying the manufacturer.</p>
<p>My camera is crap but the belt I made isn't. It's only a 4-loop weave and my waist is narrow, so I've only got roughly 40ft. of paracord on it, but I chose a buckle that's not only a whistle, it's also a flint and striker.</p><p>...now I just need to decide on the best way to put a compass on it, given that I tried and failed to weave it on.</p>
<p>I just finished mine. </p><p>Specs:</p><p>Waist Size: 33&quot;</p><p>Belt Length: 48&quot; or 4 ft not stretched. </p><p>Using a 6 loop weave its about 8-10&quot; per weave.</p><p>This results in 96-120 ft of paracord being used in the on belt.</p><p>Thanks for the great 'ible!</p>
You know? I've tried to hang myself with many different kinds of belts at &quot;low points&quot; in my life. However, now that I've seen and learned to weave my own belts and other things I have a new sense of hope. I would like to thank you so very much for this post it is a breath of fresh air to me. Now, I can rest assured knowing that when I wrap that belt around my neck I'll truly appreciate the strength, durability, and craftsmanship that's gone into it.
<p>I'm struggeling to tell weather this is sarcastic or not...</p>
<p>If we never hear back from him again I guess we'll know. :-) </p>
<p>Thanks you for the info. well done.. :)</p>
The method of the loops used in this belt are very similar to the way knitting works, except that you are starting on the left for each row, whereas for knitting you would start on alternating sides for each row. If someone knows how to knit, it might be a little faster for them, once they figure a way to anchor the weave to the buckle. I like the idea. I just made a strap for a messenger bag, using 50 feet of 8mm paracord. Good job on the instruct able. <br> <br>OneMooreGuy
I keep thinking that it looks like Tunisian Crochet.
<p>The first time I heard of this kind of belt, I thought it was <br>awesome and tried to track back the source. The earliest I could find <br>was referred to as the &quot;Slatts Rescue Belt&quot;, using a knot apparently <br>developed by Philip Slattery. At one point, I saw a reference, I <br>believe from Slattery, that the knot was based on a modified crochet <br>stitch.</p>
<p>The first time I heard of this kind of belt, I thought it was awesome and tried to track back the source. The earliest I could find was referred to as the &quot;Slatts Rescue Belt&quot;, using a knot apparently developed by Philip Slattery. At one point, I saw a reference, I believe from Slattery, that the knot was based on a modified crochet stitch.</p><p>That would definitely explain the the similarity to knitting, too.</p>
I thought that myself and will be trying a knitted one next.
<p>Beautiful work!!!! I'm gonna give it a try.</p>
<p>ooh nice :)</p>
do you know how to finish if you use a regular buckle ?
Explain the begging better
I love it!!!! You Know I'm gonna try this one. Thanks. Looks easy you did a great job describing each step.
Awesome! It's easy to make and use! I'm going to make a gun sling this way.
What size buckle did you use?
How well do you think this would work for using a standard belt buckle? I'd think that if you made it over length, in the same style as a normal belt, it could function quite well, but I'm not sure how well the weave would hold up to being tugged at by the pin. Any clues?
This is by far my favorite belt weave! I have only been working with paracord for a couple months but I picked this one up in no time. Idk if anyone has put thought into a two color version, but i think i figured it out. <br> <br>I stopped here due to lack of paracord, and well i don't like these colors together. The process doesn't really change, but I do think that it is more tedious. This is the back side; on the front the colors are more balanced. <br>
where can i buy good paracord on the internet that ships worldwide, and where can i buy that buckle?
About This Instructable
768,934views
2,074favorites
License:
Bio: Im a firefighter living and working in Edinburgh.
More by stuwegie:Paracord Dog Collar, Halti Collar How to make a Paracord Leatherman Pouch How to make a Paracord Rescue Belt
Add instructable to:
