Step 2Hook it up.
First, you don't really need all the terminal blocks for just one generator, so take a sharp knife and cut two from the end of a string of 12. ( Mine was a 12 pole terminal block.) Now you should have a 2 pole terminal block.
Slide one 6" piece of 99.9% pure fine silver into the terminal block until it can be caught by the screw when the screw is tightened. Do the same with the second so that it is protruding the exact same length from the block on the same side of the block. ( see photo.) Tighten down the two screws to secure the wires in place.
Take the 9V battery connection and strip the wire ends so there is 3/8" bare on each wire. Fold the bare wire back at the mid-point of each bare section so there is a 3/16" double of bare wire. This will give the terminal block screw more to grip on to. Insert one wire into each of the poles on the terminal opposite the 99.9% pure fine silver wires. (see photo.)
This portion is optional as it depends on the container being used, but you can bend the wires slightly so the terminal block rests on the rim of the container, outside the container. (see photo in next step also.)
Add Comment
![Turn Copper Pennies into Silver and Gold [Chemistry Trick]](http://img.instructables.com/files/deriv/FEY/BTMU/G9C6ZF01/FEYBTMUG9C6ZF01.SQUARE.jpg)
