Step 3Make some Colloidal Silver.
Plug in the battery. Simple and easy.
A note here to never allow the two wires to come into contact with each other, or anything metal, when the battery is hooked up. It will short the battery and cause sparks.
Take a glass ( always glass - no plastic - no metal - just glass.) and fill it almost full of distilled water. Slide the 99.9% pure fine silver wires (I'll call them electrode from now on) into the water.
After a short time (15sec.) you will see bubbles form on the negative electrode and what seems like smoke will come from the positive electrode. This smoke-like material is silver being emitted into the water. About 0.0001 microns in size.
You will also notice that the positive electrode will start to tarnish, or turn blackish. No problem. Pull the electrodes from the water when you feel uncomfortable and wipe them off with a napkin, making sure not to allow them to touch each other. Now put them back in and continue to make colloidal silver.
You may notice that the positive electrode in the photo is getting thinner than the negative electrode. This device has about 40 hours on it with 14-AWG 99.9% pure fine silver wires. I am to the point where I will reverse the polarity of the electrodes by switching the location of the wires on the terminal block. The other electrode will than begin to emit the silver and tarnish.
The research I follow stated that this method and power should get me 1ppm (part per million) per minute of operation. I am sure that there are people will disagree, but this is what I go by because it works for me. So there.
I have heard that a strong dose is Tbsp of 5ppm per day. I have heard of 300 times that dose for years with no negative effects. You know you and yourself - you do what you are comfortable with. As long as it is 99.9% pure fine silver, I have heard of no deaths ever related to colloidal silver.
Add Comment
![Turn Copper Pennies into Silver and Gold [Chemistry Trick]](http://img.instructables.com/files/deriv/FEY/BTMU/G9C6ZF01/FEYBTMUG9C6ZF01.SQUARE.jpg)
