3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a Portal Gun
Step 12Papier-mache the lot
With the front shell, I built up the shape with plasticine to thicken the shell and add depth. The big shell didn't need it so was left as wire. Each shell is then coated in several layers of newspaper strips and a mixture of 50/50 PVA glue and water. You could use fibreglass resin if you wanted extra strength but the newspaper is just as good and readily available. Use small strips of paper to prevent creases and cover evenly with the glue mix using a paintbrush (just like in Art Attack). This is particularly crucial on the large shell to get a smooth curvy finish. Cover the handle shell on both sides but the big shell only needs covering on the outside.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
54
Author:chiok(Chiok Li Designs)
Completed a masters in mechanical engineering and then realised I didn't want to be an engineer. So I'm a freelance propmaker and costumier for film, theatre and music videos. Occasionally, I need t...
more »
