3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a Portal Gun
Step 4Building up
Building up
Now we're building up the profile of the model. This part was made from 18mm plywood shaped out with a router to get a 100mm disc. Drilled a hole in the centre of the disc and screwed a bolt to it so I could but the disc on the drill press, get it spinning and use a file to shape the radius on the disc. Then used the router again to cut out the centre and form a ring with an ID of 75mm (to slide over the barrel) and OD of 100mm all shaped nicely. If you have a big enough radius bit for the router, you can use that, or just painstakingly sand away the shape.
A ring is shaped out of foam from a kneeling garden mat which was thicker and stiffer than the exercise mat. Hot glue the two together and then hot glue the ring onto the barrel.
1 comment
Jul 14, 2009. 4:53 PMcillen says:
What does OD And ID stand for?
Jul 18, 2009. 8:28 AMt-ram says:
outer diameter an inner diameter
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
54
Author:chiok(Chiok Li Designs)
Completed a masters in mechanical engineering and then realised I didn't want to be an engineer. So I'm a freelance propmaker and costumier for film, theatre and music videos. Occasionally, I need t...
more »
