3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a Portal Gun
Step 7Adding detail
Adding detail
The wood sandwich is the basis of the windowed section of the gun. The wood is skinned with a thin plastic cut from an old A3 art folder (the folded black type with a handle and clasp). The plastic is easy to cut with a knife and is stiff enough to hold shape.
A rectangle of plastic long enough to cover the top curve and half as wide is cut out. 9 slits are cut so the plastic can fold alternately between stright and L-shaped to form the windows. Scoring the back of the plastic helps it crease nicely. Another strip of foam was glued to the barrel underneath the plastic to give the depth. All the folds are hot glued down so they stay put.
2 comments
Aug 23, 2010. 2:11 PMxXnocturnusXx says:
i think im going to use fix all or some kind of filler instead of manila or tape....it just seems like it would be cooler solid...
Dec 23, 2009. 9:05 AMhampst says:
i couldn't get the straight pieces to glue down... and i was impatient, i admit that now. So, for what ever reason, i used electrical tape XP
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
54
Author:chiok(Chiok Li Designs)
Completed a masters in mechanical engineering and then realised I didn't want to be an engineer. So I'm a freelance propmaker and costumier for film, theatre and music videos. Occasionally, I need t...
more »
