Remove these ads by
Signing UpStep 1Materials
4 or 5 Disposable flash cameras (I went to a camera store and asked them for some and they took a big box with about a hundred in it, they sold them to me at ten cents a camera, I only got ten)
aluminum foil
plexiglass
wire
small switch
big switch
aluminum or steel rails
6 nuts and bolts
wire hanger
tools;
screwdriver
soldering iron
duct tape
wire strippers
wire cutters
http://www.bestbuy.com/site/SoundStorm+-+3.5-Farad+Capacitor+with+Digital+Voltmeter+-+Black/3404668.p?id=1218399212520&skuId=3404668&st=capacitor&cp=1&lp=11
Will it work when wired correctly?
And I can set up the switches the same? And what size power source should I use to charge it up?
To release sparks, a railgun doesn't have to be THAT powerful, but it still requires a fairly large amount of energy. In short, THIS railgun can't be used to kill people or do any heavy damage.
I just found all of this information,
Watt x Time = Joules This is 8948 time 3600 secconds = 32,212,800 joules which is a pretty good conversion for the one minute I put in.
Power x Time = Work (energy)
Joules/distance = Newtons
Work/distance = Force
So you can convert power to energy, its just a little more complicated than most conversions.
But charging and equations are not linear which you are assuming. By your logic you can convert Joules into cubic meters
You are not converting. You are doing calculations. A conversion changes things that are equivalent. You can only change Joules into other energy units.
Further, you are ignoring inefficency, heat transfer, momentum and impulse, how magnetic fields work, charging and discharging of capacitors and other things.
Also, the electricity that is used is in watt hours when calculated.
That is what is what is wrong with what you are doing.
Joules are a measure of energy (energy is defined as the ability to do work)
Work is power * time and is measured as an SI unit of joules
Power is the rate at which work is performed or energy is converted
Time is, well you know what time is
By looking closely at these properties you can conclude that power over time is work or hp over one hour is joules
When I use the word over I don't refer to a fraction or division problem I refer to something occurring over a period of time.
what can it punch through.
can you safely hold this?
if not you can make a remote turret with a camera and use it for defense :)
