Step 3The circuit
solder the extra capacitors onto the current on (remember to keep the positive and negative sides together)
solder two long wires to the capacitors
solder the big switch onto the positive wire
in series the capacitance halves. that is no good. the voltage TOLERANCE increases, but that doesn't mean they will charge up to thousands of volts. capacitors only charge to the voltage you put in.
Can someone explain how I can mod this? It makes sense for cameras, but not for railguns.
Use an external battery box and connect + and - to where they belong, but add a "On/Off Switch" on the + wire. Then instead of adding a switch to the charge like stated in step 2, just connect with a wire without a switch.. If done correctly, after charging up, you can turn off the power and will prevent an auto-recharge (unless you keep the power turned on).
