loading
Step 7: The Tail
The tail consists of an Our Father, three Hail Mary's, another Our Father and a Crucifix/Cross.  Since you have two tails and would like only one you will have to remove the short one.  The cleanest way to do this is to hide the end in the next Our Father knot.  Set both tails on your finger like you did for the joiner knot but this time wrap the long tail around your finger five times.  Send the long tail through the loops and position the knot against the joiner for proper spacing, then tighten just a little bit but not all the way.  Cut the short tail and singe the end just short of the end of the knot.  When you tighten the knot the rest of the way the tail will disappear into the center of the knot.  You can now tie the last three Hail Mary knots.  The next step will depend on whether you have a crucifix or are making a cross from paracord.
<p>This is a good tutorial. I make the same knot using 2 wraps for Hail Mary knots and using 4 wraps for the Our Fathers on my Combat Paracord Rosary that I sell at RuggedRosaries.com. </p>
<p>Hi Sandy. You wouldn't happen to have a &quot;how-to&quot; for the knots that you use, would you? I plan to attempt to make my own rosary out of paracord in the next few days but I can't seem to find the style that I want. However, the ones in your first picture are exactly what I'm going after! I plan to make mine with wooden beads but the knot holding the crucifix and where the centerpiece would be are perfect for what I have in mind. Any advice is welcome.</p>
<p>I make these all the time... Here is my website with a lot of examples of these rosaries made with paracord... all knotted. Maybe this will give you more ideas for the design. <a href="http://www.cordbands.com/pages/knotted-combat-rosary-gallery" rel="nofollow">http://www.cordbands.com/pages/knotted-combat-rosa...</a></p>
<p>Hi Shannon. You wouldn't happen to have a &quot;how-to&quot; for the knots that you use, would you? I plan to attempt to make my own rosary out of paracord in the next few days but I can't seem to find the style that I want. However, the ones in your first picture are exactly what I'm going after! I plan to make mine with wooden beads but the knot holding the crucifix and where the centerpiece would be are perfect for what I have in mind. Any advice is welcome.</p>
I made it with a variation. I used a bead that I put knots in each side for the Our Father. I had to finish it off a bit differently. But a good project. Thanks!
I love &amp; collect Rosaries! I recently started my paracord hobby by wrapping stethoscopes with paracord. Yesterday I bought some #95 paracord and little wooden crosses. Wish me luck!
<p>Great tutorial I was trying to make these years ago when I was in the Marines...better late than never. I put my own spin on it and gave it a try in leather</p>
<p>My first one turned out over 3 feet long, so really keep those knots close together! </p>
<p>They only had 21-foot sections of parachord at my local Michael's, so I bought two of them and joined them in the center using a Hunter's bend knot. I figured it wouldn't be too great of a compromise. I'll upload an image once I'm finished :)</p>
<p>Wooden bead, dremel tool. Carve a simple cross on the wooden bead, stain dark walnut, oil finish. Use as the crucifix.</p>
Made a few more using different colors and the shorter style. Thanks again.
Easy to follow! I love the icecube trick. Thanks for sharing.
awesome project!
<p>I make a very similar one using 4 wrap knots for the Our Fathers and 2 wrap knots very close together for the Hail Mary knots. http://www.cordbands.com/</p>
<p>shweet lol</p>
Does anyone have the instructions for making the decade rosary where the cross is in line with the beads instead of dangling off the wrist? I worry about it getting caught and knarled up and would like something that sits flush to my skin. Plus I like the look of them better.
<p>Thanks for this instructable. I made a similar rosary using your directions. The differences:</p><ol><li> I made an Anglican rosary. Four sets of seven knots with &quot;cruciform&quot; knots between.<li>Thanks to a mistake I had to correct, I attached a knotted cross by looping the ends and burying them back in the adjacent knot.</ol><p>I'm too much a klutz to manage all that twisting, gnarly paracord wrapped around my finger. I cut about an inch and a half of 5/16 ID poly tubing, then slit it down one side. That way I could use two hands freely to loop the cord around the tube, push the end through tube, pull the cord and tube out through the loops, and snug everything up. The slit let me remove the tube without pulling the cord all the way back through it.</p>
<p>Good job on this instuctable. I make similar ones using file knife knots and I sell them at RuggedRosaries.com. Using standard 550 paracord, it takes about 20 feet to make one of these. I can see how you might need up to 40 feet if you are making the hail Mary knots using triple rosary bead knots. The resulting rosary must be about a yard long. If you use a double knot instead, your resulting rosary will end up at about 28 inches long, depending on how close together you tie your knots. </p>
Found these great paracord rosaries at <a href="http://www.cordbands.com" rel="nofollow">www.cordbands.com</a>.
Found this awesome &quot;ible at the same time i found this site, figured I'd link it for everyone. There are some good tips and resources, even a video how to of this process. <a href="http://rosaryarmy.newevangelizers.com/" rel="nofollow">http://rosaryarmy.newevangelizers.com/</a>&nbsp; Great job on your rosary and the 'ible.
I was practicing the our father knots when I decided that it looked like an alright bracelet. Thought I'd share.
no offense or anything, but can someone do this but with an upside down cross, and basically this, but everything is reversed. like backwards hail mary, and a back wards father. again, i honestly do not mean to insult any one, but its a free country in which we practice free religion, and i practice satanism. if someone finds a link, or makes instructions, please contact me by my facebook. i really like how this is, but just want one suited for my religion. thanks. may your form of &quot;God&quot; bless :)
I'd recommend doing it yourself, using the Satanic number system if it has one. The knots for making an upside down cross would be the same but reversed, which should be easy to work out.<br> If you think up a sequence of prayers to suit your religion, and have a knot to represent each one, it should be good for any prayer or meditation.
ok thank you :)
No problem! And good luck on your path.
hello i am doing this for my local parish and am trying to help a bunch of (no offense) elderly people make these do you have any suggestions <br><br>thanks,<br>fidgety<br><br>P.S. nice ible' by the way and God bless
Nice Ible, if you want a smaller knot/rosary you might try taking out the inards from the paracord. I'm at Bagram AB Afghanistan right now and will try this on my time off. God bless!
Nice... :~)
great instructable...thanks much...
This is truly amazing. As a prior soldier and proud owner of a LOT of 550 cord, I will be making one of these very soon. Thank you so much for this instructable!
Thank you for this! I've finally finished my first rosary. I'm not sold on the cord cross though, the arms on mine are all wonky. I might have to break down and put a wooden cross or crucifix on instead. And @looker1995: good luck and God bless.
I'm glad it helped, I hope your fingers aren't too sore. The cord cross is a good expedient, but it is tough to get just right. If you do get a wooden cross/crucifix I would like to see how it turns out.
Oops, I gave the rosary away without taking a photo. My local Catholic store didn't have any wooden crucifixes that were quite the right size, so I bought a chrome one approximately 3.5 inches tall, which looked pretty good on the finished product. I found the 550 cord easy to tie, but the finished rosary is kind of enormous. Smaller twine was touchy as all get out (the paternoster knots really drove me up the wall), but the finished rosary was a more convenient size. I've still got enough paracord to make another, so I'll try to take pictures of the next one and add it to the comments.
Thanks for the support from both of you. It helps all of us to know that we have support back here.
Your instructable led me to look up the Rosary Army. I tied one of their standard rosaries with some mason's twine that I have, then tied one of yours. I was interested because I am headed to Afghanistan this year. I find yours, out of 550 cord, is much easier to tie. I also really like the&nbsp;hand tied&nbsp;cross. Thanks for the instructable, I will be making more of these for my friends.
I tried the mason's twine first as well. It is not very forgiving on the fingers. Stay safe in Afghanistan, we'll be praying for you.
two thumbs up, god bless you.
About This Instructable
112,952views
280favorites
License:
More by beta1072:How to make a Rosary out of Paracord Replacing Lights for '98 Ford Ranger Instrument Cluster
Add instructable to:
