How to make a Rosary
Step 5String beads
String beads
This step will have you connecting the beads to each other and to the chain pieces.
1. Group beads together. Five sets of 10 beads, one set of three, and six loose beads.
2. Connect each set of 10 Beads together in a Decade as follows:
a. Select one loop on each bead to twist open.
b. Using the flat nose pliers, twist the end open. DO NOT UNROLL the loop!
c. Place the loop of the next bead on the opened loop, and twist closed.
3. Connect the set of 3 beads as in step 2.
4. Connect a piece of chain on each loop of the six loose beads, using the same techniques as step 2.
As I usually know the loops I formed are fully closed, I select the pre-formed loops to open. Then I can be sure these are closed tightly.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:kqrpnb
Well, I am mostly a family man, which means I use "hanging out with the family" as an excuse to get less of my projects started, and a fraction of the started ones finished. I try to be passionate ...
more »
