How to make a Steampunk Easter Egg
 by jordan21892
Step 4: My Design-Legs
Before you start make sure you remember NOT TO GLUE anything in until i say to because it will make everything much easier for you.
The first thing i did was designed how it was going to stand so i picked it to have three legs so it stand level.
when your done making the legs make holes in the bottom of the egg spaced equally apart to fit the legs in. make sure the holes are just barely bigger than the leg pieces. to start the hole use the push pin then use small screwdrivers to make the holes bigger to the right size of the legs.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
