3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a Tsuba for a wooden Bokken
This is a how-to guide that I made when constructing my own wooden bokken. I read a great how-to on this site, but it didnt show me how to make the Tsuba(or guard) So I had to make one up myself.
For the Sword how-to, the link is here:http://www.instructables.com/id/EMVOZXMBO2EP286GNG/
I will also make a sword guide similar to TTF's method in the future
Step 1Making the Notch
Making the Notch
For the tsuba to fit into the handle nicely, you must first construct a notch. This can be done with a dremel tool, or by had with a chisel.
The first step is to mark where the notch will be on the bokken. If the bokken is katana length, use 4 hand over hand measures. Wakizashi, 2 and a half. Tanto, one and a half. Judge the hand method to the length of the sword.
The second step is to take your handle material(any kind of wood is ok. But it must be 1/4" or larger. Anything thinner will break.) and trace the outline on the bokken.
Afterwards, take your chisel or dremel tool, and cut out between the markings. using a wood rasp also works.
15 comments
Apr 18, 2010. 8:57 AMGINJA NINJA says:
those are some pretty close up pics; i thought the tsuba halves were about a foot long until I saw your thumb in one of them!!!!!!  =|8)  (man with a top hat on)
Jan 2, 2008. 3:19 PMkimro says:
I can tell you don't practice with a ken (Japanese term for sword) because you put "wooden bokken", bo means wood in Japanese and ken of course means sword so that is a redundant statement but other then that nice job
Jul 15, 2009. 8:43 PMbowmaster says:
ATM machine all over again.;
Apr 19, 2008. 6:18 PMbowmaster says:
Can someone post a sheath for these swords?
Jun 29, 2008. 2:08 AMknexdude152 says:
there is how to make a duct tape sheath
Mar 20, 2007. 6:49 AMzanshin says:
i don't know wether you train a martial art where bokken is used. i'm not trying to disapprove your work, but your bokken and shoto (or wakizashi) look too straight, and you would be needing the curve, for kendo and iaido at least, since several katas rely heavily on upper curve slide thrust. do you have a regular bokken at home? use it next time as a stencil.... all being said and done, it looks nicely crafted, just as long as you use it properly (i.e. hang it on the wall)
Jul 3, 2007. 1:21 AMsamuraiBSD says:
I might also add that my Iwama style bokuto for Aikido is almost entirely straight and has no point on the end. It gets a lot of strange looks. My "standard: bokuto has a lot of curve to it, and my Bugei katana has somewhere in between, if not on the curvy side. There's a lot of different styles of bokuto, so it's interesting to see what other people are using.
Mar 21, 2007. 3:31 AMzanshin says:
please do post them, from this angle they look pretty much straight. one other thins, i've seen some time ago the bokken instructable (two color one) which i saw you used to make yours. how strong has it shown up to be??? i thought of making it as well, but i didn't know if it was worth the trouble, since im not that versed in woodwork
May 8, 2007. 7:45 PMTheClockworkPhoenix says:
when i see this, i have a feeling it might feel awkward moving from this bokken to a metal sword, just because of weight alone. Also take into consideration tsuka thickness. Or maybe its just me. Anyways, the resemblance to a real katana is remarkable. good job. does anyone know how to wrap a tsuka?
May 24, 2007. 5:19 PMPat Sowers says:
A good sword has a weight of 2.3 lbs. to 3 lbs. (katana)
May 24, 2007. 5:18 PMPat Sowers says:
If you want to learn some sword techniques click on my name and then on Iaido techniques.
Mar 14, 2007. 1:23 AMVisitor says:
Please see pictures is steps 6 and 8 in the bokken instructable you linked to. The original, store bought bokken, on the left has a small notch where the handle ends and the blade starts. A proper tsuba is not glued to the bokken. Instead it is slid over the blade towards the handle until the notch stops it. The white band in step 11 is there to keep the tsuba from flying off when the bokken is used. The band is a round piece of slightly elastic material with a hole that is slightly smaller than the outer diameter of the blade. It can be made of rubber or leather, for example.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Stick4444
