3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a USB Ipod wall charger
Using the ac adapter from an old parallel port external Zip drive and a USB to PS2 mouse adapter, I made this Ipod charger.
Step 1Parts and tools
parts and tools
I used the AC/DC power adapter plug (5.0V DC output) from an old parallel port zip drive, and the ps2 adapter that came with my USB optical mouse. Two things I'll surely never use again.
The tools I used were a sharp knife, an electric multimeter, soldering iron and solder, a pair of diagonal wire cutters, and some wire strippers.
45 comments
1-40 of 45next »
Jan 6, 2007. 10:26 AMVon Klaus says:
oh yeah USB porn!
Mar 30, 2008. 9:56 PMbigt4616 says:
you dirty usbs, get a room
May 10, 2008. 2:48 AMthermoelectric says:
yea u dirty usb's..... Can i come 2 ur honeymoon
May 29, 2008. 1:55 PMzpersichetti says:
PERV!!!!!!!!!!!!!!!!! wtf kinda ppl wanna see USB's inserting into eachother!!!
May 30, 2008. 2:48 AMthermoelectric says:
Other USB's LOL
Nov 16, 2009. 4:18 PMMajorRockstar7 says:
 enough with the madness
as long as you get it on video i will take a copy
May 30, 2008. 12:51 PMzpersichetti says:
lol i can imagine it now.... Playdrive with USB Heffner
Jun 16, 2008. 12:42 PMOra says:
More like HughSB Hefner
Aug 3, 2011. 4:21 PMcrazydog75 says:
that was awesome.
Jun 16, 2008. 2:01 PMthermoelectric says:
lol
Jun 16, 2008. 1:24 PMzpersichetti says:
lol yup
Jun 16, 2008. 10:30 PMthermoelectric says:
lol
May 30, 2008. 5:22 PMthermoelectric says:
lol
Jan 20, 2010. 4:33 PMChromatica says:
LOL
Jan 3, 2010. 5:03 PMseverepb says:
thanks. this gives me a great idea, sorta
Sep 19, 2009. 12:24 PMExterminate... says:
This worked fine for non-IPod devices, but it only tuned my nano on (no charging) and did nothing to my iPod touch. I then found this: http://www.instructables.com/id/How_to_get_your_iPod_to_charge_with_your_homemade_/ . Apparently the data lugs must carry some power for an iPod to charge. Thanks apple for your complete control freakery
May 22, 2009. 11:32 PMsixpakal says:
Really, We are making a female? USB pR0n or primitive robot girlfriend? Your pick.
Oct 27, 2008. 5:03 PMbradyman3 says:
I have a 80gb ipod classic and nothing happend I used a 5vdc charger. Should I use A bigger voltage??
May 1, 2009. 6:25 AMswishinj says:
does this work on iPod touch 2g
Mar 29, 2009. 9:02 PMScott9 says:
Hmm nope, it should work fine with 5V
Dec 29, 2008. 8:24 PMhalberdear says:
umm...80gb or 8gb?
Nov 6, 2006. 7:51 PMLasVegas says:
Great idea to save on the cost of an iPod wall charger. And a use for all those extra PS/2 to USB adapters! Your warning about having the brick unplugged before working with the wires isn't necessary since the 5V out of that brick isn't enough to even feel, let alone do damage to your being. There is a danger of harming the power brick in the event of a short though. There is no danger of harming a multimeter at all. Worse case scenario would be try to test with the meter's wires plugged into the Amp lines and the wires themselves no having enough internal resistance to prevent the power brick from shorting out. This is very unlikely. Also, the white line (or ridges) on the power wire will almost always be the negative line. You never know when the supply is made in some parts of the world. It doesn't hurt to verify this with a volt meter. It would have been nice to show your soldering work on the connector itself. and how the data lines would be cut short to prevent any possibility of inadvertent shorts. All in all, a very good instructable! :)
Jul 12, 2008. 6:58 AMDerin says:
most digi meters have about 10meg internal resistance
Mar 18, 2009. 1:11 PMzaketus says:
When probes are plugged into the "amp lines" (=connected to measure current), resistance is something very small, so voltage drop is as small as possible, when measuring current. That's the same reason, why DMM's resistance is 10Mohm, when measuring voltage: to have as small effect on circuit that is about to be measured (of course, in some cases 10Mohm isn't enough).
Jan 18, 2009. 7:02 AMjjon says:
I made one of these before I read this. It works great too.
Aug 28, 2008. 10:50 AMevanwehrer says:
OH MY GOD I DID THIS EXACT THING! Even with the same wall adapter.
Dec 18, 2007. 5:12 AMmannyhall says:
is it important to have this ....
Intelligent IC chip inside recognizes a fully charged battery and automatically switches to a saver mode to prevent overcharging and short circuit.... (some charger has this feature).
Based on FAQ from kensington website, keep charging the ipod is not a good thing, see here:
http://kensington.custhelp.com/cgi-bin/kensington.cfg/php/enduser/std_adp.php?p_sid=29SG2wTi&p_lva=&p_faqid=652&p_created=1122495781&p_sp=cF9zcmNoPSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTQmcF9zZWFyY2hfdGV4dD0mcF9wcm9kX2x2bDE9MjUmcF9wcm9kX2x2bDI9fmFueX4mcF9jYXRfbHZsMT1_YW55fiZwX3BhZ2U9Mw**&p_li=
(it looks like iPod has no built in auto-stop-charging). What do you guys think?
Dec 20, 2007. 12:43 PMNickthetinker says:
The reason why the fully charged battery shouldn't be affected by a charging voltage is that is that the charging circuit should be applying the same voltage to the battery as it's maximum (fully charged voltage). The result is a net current of zer0. IRL there is still a small trickle which serves to maintain the battery at full charge. There is some debate as to whether it is better to charge a battery whenever it is used or to run it completely out. I have heard convincing arguments for both, but I always charge my cordless drill and cellphone whether they are dying or not so why not an ipod? As for the mysterious smart charging ipod microchip there isn't one in the usb cable, and the usb is always 5VDC hot. No warnings to not plug an ipod into usb...
Dec 4, 2006. 11:34 PMdfc849 says:
hey can i use a 5V 850mA or a 5V 2.0A charger for my nano? the 5V 850mA is un anused RAZR charger, i dont know where the other one came from
Oct 16, 2007. 7:00 AMDeadlyDad says:
According to the official USB specifications:
"The power source and sink requirements of different device classes can be simplified with the introduction of the concept of a unit load. A unit load is defined to be 100 mA. The number of unit loads a device can draw is an absolute maximum, not an average over time. A device may be either low-power at one unit load or high-power, consuming up to five unit loads."
Which means that anything that can supply at least 500mA per port (i.e. two ports require a 1A supply, etc.) or more is completely within spec. If you have a 2A supply, I would just pick up a cheap four port hub and use that.
Mar 7, 2007. 9:15 PMminisharkx says:
ok im making something simaler to this using the ps/2 adaptor thing and it helped alot i got the female usb perfectly this time but now i need some help i need some kind of electricity conducting glue since im only 15 dont have a job and my dad keeps his solder at work
Mar 7, 2007. 9:05 PMminisharkx says:
careful when cutting away the epoxy glue, i cut my finger open on accident and it didnt hurt as much as bled for 5 minutes, so if your using just a razor without a handle -points to the emos- then be careful or wrap your fingers in some kind of tape as a precaution
Feb 3, 2007. 5:14 PMremyzero7 says:
some advice on where to find the "sharp knife" you used would really be appreciated. i managed to cut the thing open with a pair of dykes & an exacto knife, but the exacto cuts on my fingers weren't awesome. but then, i've got gorilla hands... :-/. Thanks for the idea, though! I really wanted a female USB jack to walk into my hands, and here i had one all along...
Feb 13, 2007. 10:25 PMremyzero7 says:
Good call! I keep forgetting that all of the answers are right here if you know where to look. Cheers- Remy
Feb 10, 2007. 2:10 PMBad Donut says:
I found it interesting that the zune (my friends, i would NEVER get one) comes with a commercial version of one of these
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:pir8p3t3
