3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a USB Ipod wall charger
Step 2Cutting away the dead wood
cutting away the dead wood
The hardest part of this project, and the only place where you can make a mistake!
Obviously the zip power supply should not be plugged in unless we are ready to test it with the multimeter.
First we'll prepare the (unplugged!) AC/DC power supply. Clip off the DC plug end, split the wires back about 1" being careful that the wires are both individually insulated (not exposed), and strip them, exposing ~1/4" of wire.
Check again to make sure that you haven't somehow left the adapter plugged into the wall, and if not, grab the bare wire, and twist it with your fingers to make it nice and tight.
*danger* During this step under no circumstances let the bare wires touch *danger*
*warning* Be familiar with the proper use of your multimeter *warning*
Set the multimeter to measure DC Volts, and test the wires with the adapter plugged in.
Once you have determined which lead is positive and which is negative, write it down.
Double check.
If you get it wrong, you may damage your Ipod, and that would suck.
Now to prepare the PS2 to USB adapter, you'll need a sharp knife.
Slice the outer plastic on the adapter from the PS2 end of the adapter to about 1/2" from the USB end, pull it open, and cut away the epoxy glue and wires inside leaving only the soldering lugs on the back end of the USB plug. This may require the diagonal cutters again, but I did it all with a sharp pocket knife.
Also, don't cut yourself like I did.
The picture below shows the pinout for a male USB plug, like the one at the end of your Ipod adapter. It's probably best to clip off the data lugs (middle two) before proceeding to the next step.
5 comments
Sep 19, 2009. 12:24 PMExterminate... says:
This worked fine for non-IPod devices, but it only tuned my nano on (no charging) and did nothing to my iPod touch. I then found this: http://www.instructables.com/id/How_to_get_your_iPod_to_charge_with_your_homemade_/ . Apparently the data lugs must carry some power for an iPod to charge. Thanks apple for your complete control freakery
Mar 7, 2007. 9:05 PMminisharkx says:
careful when cutting away the epoxy glue, i cut my finger open on accident and it didnt hurt as much as bled for 5 minutes, so if your using just a razor without a handle -points to the emos- then be careful or wrap your fingers in some kind of tape as a precaution
Feb 3, 2007. 5:14 PMremyzero7 says:
some advice on where to find the "sharp knife" you used would really be appreciated. i managed to cut the thing open with a pair of dykes & an exacto knife, but the exacto cuts on my fingers weren't awesome. but then, i've got gorilla hands... :-/. Thanks for the idea, though! I really wanted a female USB jack to walk into my hands, and here i had one all along...
Feb 13, 2007. 10:25 PMremyzero7 says:
Good call! I keep forgetting that all of the answers are right here if you know where to look. Cheers- Remy
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:pir8p3t3
