How to make a USB by using dead battery
 by Indiana67
Step 4: Remove the carbon lining
Hold the battery in a cloth and use either a drill or a countersink to carefully and slowly grind out the carbon.
A 12mm bit should fit inside the battery quite neatly.
Stop every now and again to empty the carbon dust out of the battery casing.
CAUTION : If you drill too fast, the casing will get too hot to hold, or the drill will clog with dust and snatch the casing from your hand.
When the casing is empty, wash it again and clean it with a piece of cloth on a screwdriver.
Carbon dust is electrically conductive, so you don’t want to leave any in there to short out the USB circuitry.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
