I made it in about 2 minuts.
But there is not enough power from the USB port so the fan spins fast but not fast enough.
sorry about that but it produces enough thrust to move a piece of 4mmX4mm paper.
I used some images from the web because i couldn't take the right photos.
Remove these ads by
Signing UpStep 1Get the parts and tools
1 brushless fan
screwdriver
1 USB cord
soldering iron
solder
sticky tape
2 paper clips
Here's my question - A 5 volt fan would draw enough power from a standard USB port. However, will the 5 volt fan be able to draw a similar amount of power from a USB hub? Probably yes, you would think, if the hub were running on AC power. So, would two 5 volt fans draw 5 volts each from a two port USB-powered USB hub?
