How to Make a USB to Light Up an LED Using Bare Conductive Paint Pen
Published
Introduction: How to Make a USB to Light Up an LED Using Bare Conductive Paint Pen
What you need:
Bare Paint Pen
Pen/Pencil
LED
Cardboard
Ruler
Scissors
USB port
Optional:
Heat Gun (if you’re impatient)
Hot glue gun (if you don’t have thick cardboard)
Step 1:
Take a piece of cardboard large enough to draw 2 lines 12 mm wide and 75 mm long.
Step 2:
Draw two lines about 70 mm long 5 mm apart starting at the edge of your cardboard.
Step 3:
Paint over the these lines with the Bare conductive paint pens making each line about 1 mm thick making sure they do not touch
Step 4:
Cut the cardboard out so it is thick enough to fit snuggly in your USB port (or hot glue several pieces of cardboard together) and about 75 mm long.  **Check to make sure that it fits into your port.
Step 5:
Put the LED on top of the two lines and put more Bare paint to “glue” it down.
Step 6:
Wait 10-15 minutes for the paint to dry or use a Heat gun until the paint is no longer tacky. Be cautious that the paint will expand when heated.
Step 7:
Insert your LED/cardboard USB into your port and watch it light up!!
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
