3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a WoW Private Server in 15 minutes!
Step 6Changing your realmlist
Go to your WoW directory. There is a file called "realmlist.wtf" Open it with Notepad. Delete everything, and write "set realmlist 127.0.0.1" in it.
To start your server go to your "C:/AC Web Ultimate Repack/" Directory and run "Control Panel.exe", then click on the first three buttons (we don't need Apache, it just slows down your computer).
We're finished! you can play now on your own WoW server for FREE!
51 comments
1-40 of 51next »
Aug 21, 2011. 1:08 AMOsmolaman says:
I can log in successfully, and when I double click my server it just says "You have been disconnected from the server". Please help me, I don't know what else to do.
Aug 20, 2011. 1:24 PMsamma99 says:
derectly when i press on my server i got dc can some1 help???
plz
Apr 30, 2011. 7:14 AMpadi08 says:
i get to select realm screen and when i click on it, i get disconnected from server can anyone help
Mar 17, 2011. 2:56 AMmschetinin says:
I'm assured that this DOES NOT work for 3.3.5. I had problems with "Unable to validate game version," then once that got fixed it was stuck at connecting. Even after trying to port foward to all the of the ports above.
Mar 2, 2011. 11:25 PMðmùîr says:
ok so i've done everything . i can login and then i find my server . it gets to the connect screen and just hangs
Feb 8, 2011. 10:16 AMjamesjph says:
The Repack link does not work.
Try this: http://www.d3scene.com/forum/wow-private-servers/36364-ac-web-ultimate-repack-9-0-a.html
Jan 30, 2011. 7:38 PMValaar says:
Hey man ummmm how do i make it so i can be like a GM and spawn things and change class configurations and such???
Jan 8, 2011. 8:47 AMkornello says:
help! when i started "logonserver" after a few seconds it closed:
http://img6.imageshack.us/i/wowprivateserver.png/
Aug 20, 2010. 8:20 AMcramboslice says:
it also says for me failure to validate game version. i have wotlk 3.3.5 version 12340 and i still cant get in. any ideas?
Dec 29, 2010. 11:46 AMPaulbob says:
go here:
C:\AC Web Ultimate Repack\Ascent\ascent-logonserver.conf
the edit the following
MaxBuild = "99999">
Note: the above contains an extra 9.
(The 4.0.3 build of cataclysm is 13329 or higher. i ran into same issue, so just make that change. im still having trouble after i got [ast that road block)
Jan 3, 2011. 8:55 AMKungr says:
I did that and a lot of other numbers aswell but it still comes up.... Any ideas for fix?
Dec 20, 2010. 1:16 PMSwiftLegend says:
My world.exe keeps crashing, any help?
Nov 17, 2010. 3:05 PMnikolarale says:
I do all job finnish. But when i try to log in (admin admin) I got:
,,success,, or
,,retrieving of realm list,, or
,,authenticating,,
Its random,and going again and again...
BUT NOTHING HAPPEND THEN. I can only click at cancel??
I trie to wait 5 minutes and noting happend...
How you got that work?
Reply soon! thanks...
Nov 1, 2010. 3:36 AMnate11985 says:
ok i can now connect too my realm but i get the screen where it says "Connected" and it just stays there. Its not frozen or anything its just there and wont go to the next screen :( how would i fix this problem??
Nov 1, 2010. 3:27 AMnate11985 says:
ok ive got a couple questions here...
First off, when i type admin for the username and admin for the password the realm list comes up and i select my realm and then i get a box that says connecting/connected. but it takes a reeeaaaaaalllllyyyyy long time to load. Is there any way too speed it up a bit?
Second, most of the time the screen will stay there on connected and/or connecting. Is there anything that i can do too fix this?
Oct 31, 2010. 11:38 AMxbjornx says:
I chose my server and pres "okay". but then it is stuck on connected=(. what do I do?
Oct 31, 2010. 5:40 AMxbjornx says:
when i loggin it is stuck on "connected" and then it says "loggin server down" what do I do?
Oct 31, 2010. 5:25 AMxbjornx says:
need help! when I start "logonserver" it just closes again and the "Ascent" says it fails to connect. what do I do?
Oct 24, 2010. 11:22 AMviruzz says:
I get stuck on connected tell me why....
Oct 20, 2010. 1:51 PMviruzz says:
how do i update to patch 4.01?
Aug 1, 2010. 8:41 PMHammrock says:
Alright, I'm getting that "unable to validate game version" message, and I tried to change the max/min build thing as much as possible, but it won't work, is there anyway to fix it?
Mar 12, 2010. 5:13 AMCobraclaw0011 says:
It all works up until I hit enter and select my server, it then gets to the "connected..." spot and then stops. Help please?
Jul 29, 2010. 9:01 AMdeathwaz says:
hi. i have windows 7 and i was playing wotlk after i reinestal my windows,i could play wotlk but today,my wotlk just stay on connecting. i changed my server and play with that server for about 1 houre but i dc and after that i wanted to connect but my wotlk stay on connecting again and dont connect to that server too. i disabled my firewall but it dosent work and i dont have antiviros what should i do? and i dont know what is router and how i should forwarding my ports. please help me.
Jul 6, 2010. 8:15 PMDrigo2012 says:
Hello, I get an error saying that It cannot validate the game version. How can I fix that?
Jun 25, 2010. 12:11 AMdangoblin says:
Hey, i did everything you guys said.. i have the most recent repack,im running patch 3.3.5, i forwarded the ports, and i ran the 3 things.. But now it gets stuck at authenticating. when i look at the Arcemu-logonserver, it did some stuff and now its saying: D [Arcemu] AuthSocket: Unknown cmd 19 Could that have something to do with it? Plz reply
Jun 25, 2010. 12:19 AMdangoblin says:
ok heres a pic, sorry if its hard to see
Aug 19, 2009. 2:21 PMjulienlego says:
ok, plz help me!!! I have "MySQL","Logonserver", and "Ascent" open. My screen looks like this: What now??? I tried opening the retail wow launcher and used "root" as my username and "ascent" as my password (which I was told to do), but it denies the account. I then used my retail wow acount to look for my new relm in the relmlist and it didn't show up. Please respond quick!!!!
May 7, 2010. 11:26 PMdanecook says:
 ok look guy, when you open up the retail version of wow, for the username and password should both be admin. that what i got out of it. i got too frustrated and just said," screw this" and dumped all my wow private server stuff,
Mar 4, 2010. 4:15 PMdanecook says:
 i have a message on my mysql saying
[ERROR] Can't find messagefile '\AC Web Ultimate Repack\Server\mysql\share\english\errmsg.sys'
and below that it says
[ERROR] Aborting
please help.
May 6, 2010. 1:09 PMoynas says:
Hello.
I have got ever thing to work i disable all fire walls and have no internet connect.
just to remove and other port problems.
I still get the same problem After logging in it hangs on connected....
i am a ex computer repair man and have tried many other thing's
But i am stuck at this point
                          have any ideals
                              thanks  Wade
May 6, 2010. 8:10 PMoynas says:
i have know notice that ad.exe seems to lock up on one of the map files
So im doing a brand new install to night ...Will .........
May 6, 2010. 11:14 PMoynas says:
well i have installed every thing new WOW ,framework and the program used here
And this is all i can get done
1. load My sql
2. load logon server
3.Load World
4.Run WOW
wow logs in goes to reallist click on real says connected and thats it
I have tried a lost of these in the past and have never seen one that works
If i do get it working Will post how   Ty
May 23, 2009. 6:53 PMkillgor4 says:
I did what you said but it just stays at connected. what could i do to fix this problem?
Jul 25, 2009. 9:02 AMdimi00100 says:
same for me
Mar 23, 2010. 1:04 AMroostercrusien says:
on the router things , ports and such as firewalls, if they use panda sysercuriy systems it will pick up and fix itself. very ez fix. no more hunt and peck.  Panda will ask u one time do u want to acess and u answer yes ,Done
Mar 16, 2010. 10:50 AMXeno Dragon says:
Just wondering about the port forwarding. I'm not entirely sure where to go to even begin entering the above info. I have a linksys router, and my PC is connected wirelessly to the hub, which I also have access to. I can let you know the exact model of the router if it's needed. I feel like a noob asking, but when it comes to networking, I am about as far from a Cisco Cert as I can be.
Thanks for the guide, and looking forward to a reply.
1-40 of 51next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:szlatyka
