loading
Step 6: Cut Out the Template
Using a bandsaw, follow your markings and cut out the flip-flop. Try to trace along your markings as closely as possible without digging into the form. Take your time and be meticulous about these cuts.
(If you do not own a band saw, you may use a reciprocating saw.
If you do not own a reciprocating saw, further trim the template and then use a disk sander grind away the excess)
I chose to use a band saw because it provides a level surface and it is easy to manipulate the position of the wood
After you have finished cutting out the flip-flop, quickly compare it with the original and make sure there are no large areas you forgot to remove. It is much easier to remove them with the saw now than it will be when sanding later.
I'm itching to make one now...Thanks for the inspiration.
Nice work and clever idea.<br> <br> I note you addressed the &quot;why&quot; here: &quot;A good project to gain experience with band saws and to learn the concept behind router templates&quot;<br> <br> and here: This instructable covers how to make an easily replicated wooden flip-flop paper weight / post-it note holder. They make great gifts for friends and cute desk ornaments.<br> <br> and here: all of Step 17
That definitely covers the &quot;how&quot; part. How 'bout a companion piece devoted to &quot;why&quot;?
About This Instructable
8,592views
12favorites
License:
More by shifu:How To Make A Wooden Flip-Flop Paper Weight / Notepad Holder
Add instructable to:
