How to make a altoid grill!
 by Undergroundoga
Step 1 - 1
All you need is: pencils or metal bars (bars more safe), altoid can, high quility glue like gorilla glue, and a candle. Here is a video:
Step 1: Step 1: The things
Step 1 - 1
NE patsrock says: Jul 9, 2011. 3:39 PM
glue will melt ya know and im pretty shure this wont work
A flyin muffin says: Feb 26, 2011. 7:04 PM
Wood, graphite, paint, glue, coated aluminum, wax, fire: seems safe to me!
Flipyap says: May 18, 2010. 4:10 PM
i would recommend not using pencils, because of the lead inside
cnash1303 in reply to FlipyapFeb 2, 2011. 8:18 PM
Pencils have not had lead in them since like the 1920s, they have graphite now.
geekzoid1 in reply to FlipyapNov 10, 2010. 6:27 AM
the wood would sorry forgot to specify.
geekzoid1 in reply to FlipyapNov 10, 2010. 6:25 AM
It is graphite. But, yeah the pencils would burn.
zcruizen says: Jun 11, 2010. 1:33 PM
i wouldn't recommend using pencils because they're made of wood and might catch on fire
ossumguywill says: Aug 29, 2008. 3:26 PM
Yo mark "dimond" get a better microphone but good idea. BTW if they ever make a pendragon movie i want u to be in it :)
trevor3693 in reply to ossumguywillMay 16, 2010. 3:20 PM
haha i just started reading that series. i agree.
BeanahVulgaris says: Sep 11, 2009. 10:48 AM
ok... first of all, you can get a safe metal to cook on at the store..... or recycle it from various stainless steel peices. Knives that get thrown away is one example... if you want to permanently attach the metal to the altoids tin, there is a method used in 3rd world countries that is effective but VERY DANGEROUS !!!! Use a step down transformer to get a high current source. attach one wire from the coil to the altoid tin, then use the other lead to touch the joint where you want to weld it. again... this method is probably as dangerous as wading into a lagoon full of hippos. another method would be to find stainless steel support wire or something. Poke holes either side of the altoid can and thread the steel wire through.... To reduce off-gasses from the altoid tin heating up, you could place it in a very hot fire till it glows bright red, then dunk the thing in water... I dont know how effective the hardening would be... but anyways... i'f i get around to constructing a healthier version, i'll post it! (i just have to finnish the altoids first!)
twenglish1 says: Apr 11, 2008. 9:52 PM
pencils?? WTF!!!!!
Kwitmeh3 in reply to twenglish1Sep 6, 2009. 6:02 PM
glu?? WTF!!!!!
Kwitmeh3 in reply to Kwitmeh3Sep 6, 2009. 6:03 PM
glue
Kwitmeh3 in reply to Kwitmeh3Sep 6, 2009. 6:06 PM
and pencils WTF!!!
ebqbbqmaster in reply to twenglish1Aug 18, 2009. 4:01 PM
iWTF
unpicky says: Jul 28, 2008. 12:20 AM
if anyone says that graphite is flammable again. please come over so i can slap you in the face. sure the wood around the pencil is but not the graphite
Kwitmeh3 in reply to unpickySep 6, 2009. 6:04 PM
well i wouldnt cook on pencils..... or would i?
Kwitmeh3 in reply to Kwitmeh3Sep 6, 2009. 6:04 PM
would i?!!!
lucek in reply to unpickyAug 2, 2008. 9:54 PM
I was going to refute you but no your more right. graphite will burn (like how diamonds wold burn) but "very flammable" that's just wrong.
Rotten194 in reply to lucekMar 21, 2009. 10:51 AM
Diamonds don't burn, they go up in smoke, e.g. vaporize.
NE patsrock in reply to Rotten194Jul 9, 2011. 3:41 PM
where do u get diampnds
lucek in reply to Rotten194Mar 23, 2009. 8:53 PM
depends on your definition of burning. they don't just vaporize except in a halogen free environment, they do undergo combustion every where els. the difference is the fact that the latter changes the chemical composition from pure carbon to CO2, CF4, CCl4 etc. now the reaction produces less energy then is required to maintain the reaction so you could claim diamonds don't burn like wood, or paper but by my definition they do burn.
unpicky in reply to lucekAug 3, 2008. 5:40 PM
graphite is made of carbon and has no hydrogen bonds, you need hydrogen and oxygen to burn.
lucek in reply to unpickyAug 3, 2008. 11:44 PM
all nonnobal gases will react with an Oxidizing and not all Oxidizing contain oxygen. fluorine and chlorine in the gaseous state, and bromine in the liquid state will act as Oxidizers.
lucek in reply to unpickyAug 3, 2008. 11:03 PM
no you don't. how dose magnesium burn then? or aluminum powder? there is no hydrogen so by your theory they shouldn't burn.
unpicky in reply to lucekAug 3, 2008. 11:38 PM
that uses very high temperatures, magnesium burns at like 3,000 F. it would take very high temperatures to ignite the graphite and a grill couldn't do it.
lucek in reply to unpickyAug 4, 2008. 2:22 AM
yes and if you look back I said "graphite will burn (like how diamonds wold burn)" then you replied eroniously "you need hydrogen and oxygen to burn."
imgod22222 in reply to lucekAug 10, 2008. 7:28 AM
you don't need hydrogen to burn. just oxygen. combustion is adding oxygen. *thank you, 7th and 10th grade chemistry!*
lucek in reply to imgod22222Aug 10, 2008. 9:56 AM
you kneed one of the halogens, Examples of this includes fluorine and chlorine in the gaseous state, and bromine in the liquid state.
Sgt.Waffles says: Mar 18, 2008. 11:08 PM
You REALLY want to cook food on coated aluminum?
xZCodmaNZx in reply to Sgt.WafflesApr 12, 2008. 2:01 PM
no
Rokko8652 in reply to Sgt.WafflesApr 7, 2008. 3:34 PM
I would take some Tin foil to put into the tin so it would be safe.
yourface101 says: Jul 9, 2008. 7:09 PM
ok, let me rename it:"how to make an altoids deathtrap"
stranoster in reply to yourface101Jul 24, 2008. 11:28 PM
Oooh, catchy. :)
miniman980 says: Jul 20, 2008. 6:02 PM
very cool idea, i want to try it! would paper clips work? and you could avoid the glue issue if you hooked the paper clips around and maybe soldered them cook mini marshmallows!!!!!!!!!!
cdousley in reply to miniman980Jul 18, 2009. 4:55 PM
dude solder melts with flame
miniman980 in reply to cdousleyJul 24, 2009. 7:31 PM
not by indirect candle flame
Obsessive says: Apr 8, 2008. 4:13 PM
Why in the hell would I grill anything on pencils?!
cdousley in reply to ObsessiveJul 18, 2009. 4:58 PM
smoky flavor no need for cedar chips
littlechef37 in reply to ObsessiveJul 12, 2008. 11:54 PM
YUMM Graphite or lead or whatever they make pencils out of....
Kwitmeh3 in reply to littlechef37Sep 6, 2009. 6:02 PM
graphite but UMM...... i mean YUM....... lol
Rishnai in reply to ObsessiveJul 9, 2008. 2:05 AM
Why the hell not? Gives it a nice smokey flavor...
hannahheartsyou in reply to ObsessiveMay 26, 2008. 1:39 PM
uhhhhh i dont know.... =P
cdousley says: Jul 18, 2009. 4:54 PM
ok pencis are painted thats toxic wood burns u need real pictures glue is bad under heat
mikaelthemycologist says: Apr 29, 2009. 1:32 PM
I once caught a pencil on fire, it exploded and burned a hole through my shirt. Even if the pencils don't explode (and I don't think they will) the wooden pencils would burn all of the way through except for the graphite. And then what's left of the pencils would break under the weight of whatever your roasting. So seeing that the pencils wouldn't even work, I don't think you should even mention them. Candles also leave a sooty residue on things above them, so you should make sure that your candle is non toxic or else you may be making your food poisonous. And also, the heat area over a candle is very small. So unless you are constantly moving the piece of meat around over the candle, it will only cook in a small area. It may be possible to fix this by placing a metal plate an top of the bars, and then placing to food on top of that .
HI! says: Feb 22, 2009. 10:19 AM
it's definetly portable....
awang8 says: Dec 16, 2008. 12:48 AM
The only reason I'd use metal is because it doesn't snap (easily). Boy I'm alot of brackets these days...
Kilsmer says: Oct 14, 2008. 10:57 AM
Did you actually use paint for these diagrams?
zrune18 says: Sep 18, 2008. 6:41 PM
yea cmon people graphite isnt flammable!!! the wood is graphite has some charcoal in it so it is not flammable!!
NeonLime says: Mar 19, 2008. 12:26 PM
Show A Video Of This Working. And Pencils? :l Your Gonna Get Somebody Killed In A Fire... Wood, Graphite, Not Good Tasting Food & A Fire Starter..
Undergroundoga (author) in reply to NeonLimeMar 21, 2008. 7:41 AM
Thats what I said. use iron bars there more safe!
struckbyanarrow in reply to UndergroundogaMay 5, 2008. 8:20 PM
than why did you even mention pencils the graphite is very flammable
unpicky in reply to struckbyanarrowJul 28, 2008. 12:19 AM
graphite is not flammable
dude300 in reply to NeonLimeMar 19, 2008. 2:18 PM
also wouldent the glue burn off
NeonLime in reply to dude300Mar 19, 2008. 2:51 PM
Ive Tried To Melt Super glue And It Didn't Work. If It Was Hot glue From A Hot Glue Gun; Yes
lawizeg in reply to NeonLimeAug 20, 2008. 6:36 PM
I don't mean to be mean, but why the hell are you typing like that?
struckbyanarrow in reply to NeonLimeJun 24, 2008. 5:16 PM
again< super glue and most other glues are highly flammable!
stranoster in reply to NeonLimeMar 20, 2008. 11:33 PM
I love Using Capital Letters on Nearly every Word Too!
Derin in reply to stranosterJul 24, 2008. 11:57 AM
LIKE THIS?
stranoster in reply to DerinJul 24, 2008. 11:26 PM
Correct.
someguy1234 in reply to NeonLimeMar 20, 2008. 5:05 PM
just so you know, "melting" super glue produces cyanide
cry_wolf in reply to someguy1234Mar 26, 2008. 6:32 PM
Bahaha id love the see the expression on Neon's face.
dude300 in reply to NeonLimeMar 20, 2008. 2:19 AM
thank you
unpicky says: Jul 28, 2008. 12:18 AM
has anybody in here been in chemistry or earth science? graphite is carbon and will not hurt you if you eat it, and you wont change it into some deadly poison by putting it over a flame! there is NOTHING toxic in a normal #2 wood pencil. you could eat one and be perfectly fine! *but i still agree it would be stupid to grill with pencils lol
gimmelotsarobots says: Jun 12, 2008. 5:03 PM
OOOOK. First of all, the bars need to be held in place mechanically if you don't want food poisoning. Secondly, they need to be stainless steel. Thirdly, I would make a stand for this and put some kind of butane burner made of steel contained in a separate unit to give the flame. Some candles contain lead which again can give you food poisoning. And like NeonLime said graphite+fire=danger. Noooo pencils. they would simply burn and if you did manage to cook on them, you would get food poisoning.
unpicky in reply to gimmelotsarobotsJul 28, 2008. 12:16 AM
graphite is just carbon and wont change from some fire, you could eat a pencil and be perfectly fine. there is nothing in a pencil that is toxic. but it's still a stupid idea to grill on it
ultrauber says: Jul 21, 2008. 5:30 PM
I LOVE cooking my daily anchovy on burning pencils!
Tailslvr7_7 says: Apr 15, 2008. 10:01 PM
I don't understand. You're pictures are not very good, and it's confusing.
gmjhowe says: Mar 19, 2008. 3:00 AM
Actual pictures would be good, tho the diagrams are done quite well!
Rokko8652 in reply to gmjhoweApr 7, 2008. 3:34 PM
Yes, I agree. Though most video recorders (like the one you have at the start) have a "Still Frame" feature.
littlewit says: Mar 31, 2008. 3:17 PM
good idea, lets see it built
ski539 says: Mar 23, 2008. 9:47 AM
did you even try making this?! You should actually try to finish making this and add some pictures. but besides that its a great idea.
cprocjr says: Mar 19, 2008. 10:14 PM
take pictures plz.
twenglish1 says: Mar 19, 2008. 3:09 PM
the elmers won't bond metal gorilla glue might but i recommend epoxy
Kiteman says: Mar 19, 2008. 2:02 PM
Can I suggest that you unpublish this until you have had a chance to do it for real and take photos?
YummyPancakes says: Mar 18, 2008. 6:19 PM
Also, add this to the Pocket-Sized contest! Promise I'll vote!
Undergroundoga (author) in reply to YummyPancakesMar 19, 2008. 12:05 PM
ok
nrclark says: Mar 18, 2008. 7:45 PM
This is sort of a nice idea, but I'm not 100% it would actually work well to cook on. Have you tried this out? It might work better if you used something more temperature resistant than elmer's glue and something which provided a little more heat than a tea candle. Maybe try an Esbit or something similar.
Noodle93 in reply to nrclarkMar 19, 2008. 12:50 AM
I've melted chocolate in a chocolate fondue set that just has a tea candle.
nrclark in reply to Noodle93Mar 19, 2008. 1:14 AM
Although the exact melting point varies based what kind of chocolate you're talking about, chocolate melts at approximately 100 degrees Fahrenheit. You've got to figure that there is some heat loss to the surrounding environment, but I would bet that even the hottest spot of your fondue set isn't above 150 degrees, tops. Probably well below that. I've done a lot of experimentation with various backpacking stoves, and I've never been able to come up with a design that would even boil a mug of water within a half hour or so, even with all of the heat from the candle's burn channeled onto the cooking vessel. If you imagine what it would be like to grill something on top of a pot lid covering some boiling water, this would be essentially that much heat except concentrated on a small point above the flame and probably much cooler near the edges of this 'grill'. Additionally, what would you grill in an altoids tin? A sardine? A vienna sausage?
Noodle93 in reply to nrclarkMar 19, 2008. 5:08 AM
It's a ceramic fondue set, it was just standard cooking chocolate buttons. It melted. But I'll agree, it's not enough to cook it, and neither do I think it would be very safe.
nrclark in reply to nrclarkMar 19, 2008. 1:21 AM
As a side note, plenty of backpacking stoves about this size work very well, but none of them run on tea candles. 5 or 6 tea candles packed together under a small pot could probably boil some water or cook small items, but that would be with many tea candles and probably a heat spreader. And even so, a "grill" would be a pretty far cry from that - one might expect the surface temperature of a grill to be on the order of 350 degrees or so. If you tried to cook on this altoids grill, what would probably happen you would knock it over because its balance would be rickety at best. Assuming you didn't, you would wind up with a small burn spot on your food right above the candle flame and the rest of it would be raw.
gmjhowe in reply to nrclarkMar 19, 2008. 2:59 AM
You can cook a pancake on a baked bean tin with a tealight.
mikeasaurus says: Mar 19, 2008. 12:49 AM
metal more safe
GorillazMiko says: Mar 18, 2008. 10:00 PM
Would love actual pictures, but nice idea. I don't think pencils (as mentioned in the first sentence) would work too great.
icanryme2002 says: Mar 18, 2008. 7:47 PM
you think pencils and fire work well together?
!Andrew_Modder! says: Mar 18, 2008. 7:35 PM
cool. you should have actual pix, but still great
Kevvixx says: Mar 18, 2008. 6:46 PM
I like the idea, but I would like some pictures of the real thing.
YummyPancakes says: Mar 18, 2008. 6:18 PM
Awesomely awesome! Can't wait to try it. My grandpa eats Altoids like they're candy (well, they're breath mints... close enough!)
Brennn10 says: Mar 18, 2008. 5:51 PM
Do you have any images of the finished product? That would be awesome, I really like the idea.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
